jumpy 96k playback
i just upgraded to tiger 10.4.1 and pro tools 6.9.2 and now 96k playback is jumpy. i clocked it via internal 192 interface and sync i/o with no luck. any ideas? thanks!
Re: jumpy 96k playback
this may be an obvious solution, but how many hard drives are you running. I remember when I first started in 96k land I tried running just one firewire drive and it got kind of weird after about 12-15 tracks...not saying that this is your first venture, but it's something to consider if you are only using one drive. I got nothing else... Good luck with your problem man
Chris |
yeah, everything was fine before the upgrade regardless of drives. i could run large 96k sessions off an internal sata drive or external firewire drive without problems. i'm using a dual g5 with 4.5 gig ram, hd|3 accel. any other ideas would be appreciated. thanks!
How many tracks are you trying to play off of 1 drive?
If you split the tracks between multiple drives, does the 'jumpiness' go away? |
8 tracks. i played the exact same session pre 6.9.2 with no problems, now it gives me problems. i converted the session to 48k and got the playback to be fine, but what should i do about 96k?
What do you mean by 'jumpy"?
it doesn't play back smoothly in time. it scrambles the tempo a little bit. very awkward sounding.
digi, any other suggestions? 96k is useless to me right now that it doesn't work.
It is very likely that, with the additional overhead of 6.9.2 and Tiger that you're maxing out what can be done from 1 drive at 96k. Firewire drives are qualified up to 12 tracks at 96k - if you're trying to do more than that, you'll need to split those audio files between multiple drives.
Compatibility - Hard Drive Requirements |
digi, i'm talking about 8 tracks! playing back 8 tracks from a dedicated sata drive inside my g5 does not work. the sound is jumpy. do you any any other ideas? what changed in my rig with going from os 10.3.9/pt 6.9 to os 10.4.1/pt 6.9.2?? it worked fine before...
MP4 Playback Jumpy with image movement | Old School Audio Guy | Post - Surround - Video | 3 | 01-04-2013 11:00 PM |
Playback sounds jumpy | uselessxdave | Pro Tools M-Powered (Win) | 0 | 10-12-2010 06:03 PM |
Jumpy Playback and constant crashes | neilwilsonvoiceovers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 01-13-2010 08:26 AM |
To those of you having a jumpy playback cursor in 8.0.1 with Snow Leopard | products7074740 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-10-2009 03:01 PM |
DC20 playback is jumpy on D24 | emf1138 | Pro Tools TDM Systems (Mac) | 1 | 09-22-2002 11:01 PM |
