Old 12-14-2011, 02:14 PM
Violet Violet is offline
Default A couple of hot key questions...
I have lots and lots of tracks in my template...scroll is become very tedious. Is it possible to set up memory locators in the edit or mix window so tracks 1-12 can show up with a key command....then I enter another key command and it goes to 120-132?
Also is it possible to record enable the track below or above the currently selected track with a key command?
Thank you!
PT 9.0.3
Windows 7 64 bit, 2x i7 PCs, 24GB, 3 SSD's, 5 HD's
....and a couple other toys.
Old 12-14-2011, 03:25 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: A couple of hot key questions...
Not sure about the record enable question although I don't think it's possible. You can definitely set up Memory Locations to Show/Hide tracks. Look under the Windows menu in PT. If you're on a Mac, you can hit Command+5. If you set up a Memory Location for the number 1, you would hit on the numeric keypad period-1-period to access that location, whether it's a marker, track view, windows configuration etc...
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 12-15-2011, 10:26 AM
I'd rather not show/hide, I rather just automatically scroll down through the tracks to a particular section of my template. This isn't possible?
PT 9.0.3
Old 12-15-2011, 12:22 PM
Stig Eliassen's Avatar
I use mix/edit groups to move around. If you click on the group ID in the groups list, the members of that group will be selected. I often follow that up with Ctrl+Command+Up arrow, and selected tracks will fit to window.
IHTH.
Old 12-18-2011, 11:15 AM
cwsand's Avatar
No, not the way you're describing.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 12-19-2011, 10:14 AM
Sounds good.
PT lover that sounds good I'll try that.
One last thing lets say I selected a certain track in the Edit window and want to get to it really fast in the mix window. What is the hot key for that?
I saw it in the key commands PDF 1 time and now can't find it.
PT 9.0.3
Old 12-19-2011, 11:07 AM
Sounds good.
Ctrl+Shift-click the track name to select it. That will place it at the top of the edit window, and all the way to the left of the mix window.
Old 12-19-2011, 11:10 AM
Beautiful.
Ty
PT 9.0.3
[IMG] code is Off
Couple Questions Skeeter Joplin Tips & Tricks 3 03-01-2010 03:05 AM
Couple of help questions Brazen15 Pro Tools M-Powered (Win) 5 10-23-2007 12:54 PM
Couple questions. Don Geppert ICON & C|24 5 10-05-2006 03:11 PM
A couple questions G_Bender Tips & Tricks 5 10-04-2005 08:15 AM
6.4 to 6.7. A couple questions dodo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-10-2005 01:38 PM
