X32 Rack, Pro Tools 12.5 on a Mac, Aggregate I/O Problem
By selecting "X-USB" as the Playback Engine in PT, I can input & output thru the Behringer X32 Rack just fine.
I am trying to input thru the X32 Rack and output thru the internal speakers in the Mac "Built-in Output 1-2". The output meter fluctuates, but no sound is present on the Mac. "Built-in Output 1-2" is selected as the output for the stereo audio track. What am I missing? |
The "Built-in Output" is just a label. It could have any name you can choose in the I/O Setup. In fact if you choose X-USB as your playback engine it will be the X32 exclusively and you can not choose your computer's speakers or any other output of another device.
If you really need to have this setup, you need to create an Aggregate Device in the Audio-MIDI Setup application of your Mac containing both devices, the X32 and the Mac built in device.
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Re: X32 Rack, Pro Tools 12.5 on a Mac, Aggregate I/O Problem
This is what I have done. Playback engine is "Pro Tools Aggregate I/O". It combines the Behringer X32 "X-USB" and "Built-in Output". See attached JPEGs.
One important factor you're forgetting is that Protools is limited to 32 I/O, even with aggregate audio. So if you're using all 32 outs of the X32, you won't be able to add the built in outs or any other outs.
He could probably delete a pair of outputs in the I/O setup page to get around this limitation......right?
In the aggregate definition you can move them to the first position.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
YYR123, I tried that. Still doesn't work.
The official answer from Avid is the 32 channel limitation. It's not that big a deal. I can assign X32 inputs & outputs in blocks of 8 channels. Therefore I can use "X-USB" (the Behringer X32 interface) as the Playback engine instead of "Pro Tools Aggregate I/O" and still have 24 input channels and 8 output channels - or any combination in groups of 8.
MacBook Pro i7 2.8GHz Quad Core 16GB RAM ProTools 12.5 MacOS 10.11.5 Behringer X32 Rack |
Eleven Rack Aggregate Device | opethrockz | macOS | 3 | 08-26-2015 08:29 AM |
Problems Re-amping with Eleven Rack - PT Aggregate IO | tcmoistboy1 | Eleven Rack | 5 | 05-05-2011 07:17 AM |
Aggregate I/O weirdness with Eleven Rack | Noiselab | Eleven Rack | 0 | 01-18-2011 01:03 PM |
003 Rack+ and Audio Aggregate device | M Clayton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-17-2011 06:02 PM |
Making 002 Rack an Aggregate Device? | jimbojimbo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-12-2008 01:58 PM |
