Old 06-30-2011, 02:23 PM
D_Japan D_Japan is offline
Default Digi 003 won't go into Pro Tools Aggregate I/O ??
In my Audio Midi Setup on Snow Leopard, I can't seem to get my 003 to show in an aggregate device.
Why not?
I'm up to date with both the 003 drivers and PT 9.0.3
Old 06-30-2011, 04:44 PM
Lincoln Mitchell Lincoln Mitchell is offline
Default Re: Digi 003 won't go into Pro Tools Aggregate I/O ??
Pretty sure you can't use the digi interfaces as an aggregate.
Lincoln Mitchell
Pro Tools | latest
Mac Mini Server | OSX | Current
16GB Ram | SSHD
Apogee Ensemble Thunderbolt
Old 06-30-2011, 04:47 PM
Dism Dism is offline
002/003 family as well as TDM hardware are not compatible with Aggregate I/O.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 06-30-2011, 11:16 PM
They should at least give us some drivers with the option. It's almost as if they don't want us to buy the hardware now....
Old 07-01-2011, 09:18 AM
Barry Johns Barry Johns is offline
What they want is for you to abandon the old hardware and buy their new hardware and controllers. They also don't give you the option to use your 003 controller as just a controller while using other I/O's without going through your 003 I/O Digitally. They know if they do this, tons of people will buy used 003's for just controllers only and not buy their Euphonix controllers.
Old 07-04-2011, 02:24 PM
cdavis6406 cdavis6406 is offline
Exactly, pretty crappy huh.
Mac Pro, Snow PT 10HD,Sequoia, Reaper
W7/64, PT 9HD,Sequoia, Reaper
192 HD, HD-N, 002C BLA,
BLA AGB,Autuer,Lucid,
MicroCLock, Pultec, UA, Sebatron, Focusrite, Trident,API, A-Designs, Purple Audio
Old 08-16-2011, 07:54 AM
alxt alxt is offline
Very Crappy!
Old 08-16-2011, 08:17 AM
DigiTechSupt's Avatar
Not exactly the case. The 003 hardware wasn't designed to be multi-client - meaning the controller chips in it aren't capable of handling multiple clients simultaneously. We've looked at ways to get around this, but it's a limitation of the hardware.
Avid Audio Tech Support
Support FAQ
Old 08-16-2011, 08:47 AM
Hmm, okay , but it will work as controller ,ala command 8, as will the 002. That's prob just firmware tweek. Or maybe its also hardware limitation, but wait it already is controller, if your using protools. But not without i/o. You guys are gonna make us buy those mattel controllers aren't you, or the obscene msrp on the c24. Well thanks.
Old 08-18-2011, 03:56 AM
Luc.dehemptinne Luc.dehemptinne is offline
Why not?
Well, I got the OPPOSITE situation ie: the AGGREGATE i is the only HW visible in the PT HD setup although 1- in the Sound Control panel the Digidesign HW (003) is visible and selected for Input and Output. and 2- in the Midi and Audio Configuration app (v3.03) the same selection is shown for Input and Output.
I can see a "Pro Tools Aggregate I/O" line showing internal Mac sound paths but not Protools Digidesign HW (003)
Pro Tools Aggregate set up, digi 003 (rac) + presonus firepod RickvanDunn macOS 1 10-27-2011 05:09 PM
Digi 002 in Aggregate Device bjarnegohlke macOS 3 08-15-2011 02:02 PM
PT Aggregate I/O problem for Digi 96 I/O hardware ETfromNJ Pro Tools 9 2 12-04-2010 06:35 PM
Aggregate device trouble Snow Lep! Tascam US122 won't aggregate? crizdee Pro Tools 9 3 12-02-2010 03:17 PM
Digi CoreAudio & Aggregate Devices James Drake 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-06-2008 05:51 PM
