DAE error-1122 and DSI error occurred:-1122
OK,
I have trashed Pro Tools prefs No DAE prefs to trash. Search of the hard drive shows 1 DAE file. no suffix.When I launch the DAE file, OSX wants to know what application I want to use to open it. The icon has exec text on it. Unix file I think. ALSO when I turn on the 192, it lights DO NOT flicker until I start the G5. I waited 5 minutes or so and finaly decided to power up the G5. Then the lights flicker and go solid on 48k and Int sync. What gives??? Help!!!!! |
Re: DAE error-1122 and DSI error occurred:-1122
Trash Digidesign Databases from ALL connected drives, including your system drive. Also trash the Volumes folder inside Library>App Support>Digidesign>Databases. Considering you've come this far, trash Digi Setup, PT prefs and DAE prefs (which should show up in your Users>(you)>Library>Prefs folder after you relaunch PT), as well as com.digidesign.ProToolsTDM.plist. Restart, run Cocktail, repair permissions, and get back to work with PT.
Michael James michaeljamesproducer.com www.IndieProMix.com System info: PT Ultimate 2019.6 HDX, Mac Pro 5,1 Westmere, OS 10.13.3, UAD2 Octo PCIe, 2x Lynx Aurora16 w LTHD cards, 1x Lynx Aurora(n) 32 ch analog I/O DigiLink, 4x Dangerous Convert-8 (AES via Lynx), Dangerous Convert-2 (AES via Lynx), Dangerous Vonvert AD+, Apogee Big Ben, SSD boot drive, external FW800 audio drives |
Ok,
Trash Digidesign Databases from ALL connected drives, including your system drive No Digidatabases on any drives What is cocktail?? Thanks for the help!! |
Which model G5 is this? When did this start occurring?
This page has information on possible issues with G5 Dual 2.3 or 2.7 models. The error in the alert is -1123, but the -1122 may be related. If this is your situation, you should contact Digidesign Technical Support by phone. |
Mac G5
Model 9590LL/A PCIe Dual 2 GHz Sorry I didn't post that before |
Hi all,
Thanks for all the help. It has been determined that the G5 has a bad CPU in the mother board. Its in the shop now. I though I was loosing it. There may be a issue with one of the cards so it is going in for evaluation. Thanks again |
many problems: help DSI error occurred:-1122 | helikacarvalho | Pro Tools TDM Systems (Mac) | 6 | 06-09-2013 01:25 AM |
DAE Error -1122 | Alexycon | Pro Tools TDM Systems (Mac) | 4 | 08-02-2006 10:12 PM |
Help 1122 error | Greene | Pro Tools TDM Systems (Mac) | 4 | 07-16-2006 07:07 AM |
1122 error ? | Greene | Pro Tools TDM Systems (Mac) | 6 | 06-23-2006 06:01 PM |
DSI error occurred:-1122 | BOP2NITE | Pro Tools TDM Systems (Mac) | 4 | 04-17-2006 11:21 PM |
