PT 5.0 occasionally quits unexpectedly when looping
i had a protools 5.0 loop for 4 bars only 2 audio tracks and 4 midi,after about 5 minites it just quits.
G4 /400 YIKES 512 mb ram OS 8.6 mix plus no plugins other than digirack yet installed. is there something i can do to prevent this from happening? |
Re: PT 5.0 occasionally quits unexpectedly when looping
I'm not sure but the first things I would look at would be: - RAM allocation to DAE and to Pro Tools. Depending on your system, I would suggest atleast 30MB to each, more if you can afford it. You may need to get more RAM for your system. - DAE buffer size. In most cases it should be set to 2. If it is already at 2 try increasing it. - Disk cache in the memory control panel. Makr sure it is at 512k or lower and not the default setting which can be very high depending on how much RAM you have in your system. Jon |
Pro Tools 9 wont start! Quits unexpectedly.... Quits during startup... | dbC4G | Pro Tools 9 | 11 | 03-09-2012 07:23 AM |
pro tools looping wrong audio occasionally on playback? | jmattchan | Post - Surround - Video | 6 | 05-29-2011 09:13 PM |
PT 8.03 quits unexpectedly | NOGCHOPS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-04-2010 11:46 AM |
PT 7.3.1 unexpectedly quits | schulze | Pro Tools TDM Systems (Mac) | 0 | 04-19-2008 12:27 PM |
PT 6.4.1: Audio starts looping, then PT quits | Hive Guy | Pro Tools TDM Systems (Mac) | 12 | 05-30-2005 09:27 PM |
