No sound on PowerBook PROs?
Hello! In spite of using the latest version (PT903) and updating the drivers, I cannot hear any sound when running PT on a PowerBook PRO (Dual Core, lots of RAM). I get no error messages, all the drivers are selectable, but I get no sound (I tried with PTAggregate, Built-in Out and Digi CoreAudio, same result).
Any idea, please, what might have gone wrong? Thanks. Marco |
Re: No sound on PowerBook PROs?
First thing that comes to mind is to have a look at what's going on in the I/O setup window.
What's a Powerbook Pro?
PT9 will not work on an Apple Powerbook. It only has a PowerPC processor (G3) and is about 8 years old. PT9 will require a Macbook or Macbook Pro using an Intel Processor. I'm assuming this was a typographical error and you meant Macbook Pro, Yes?
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
I'm sorry, I gave some wrong information. I have a MacBook PRO, running 10.6.8. and a dual Core, 2.93 GHz and lots of RAM. I also tried with a Fireface 400, and still NO SOUND...:-( although I selected all what needed to be (I/O Setup, Audio/Midi, etc., deleted some preferences, restarted the machine, and even lit a candle to the spirits of the PT...!). Nothing.
I then tried PT9 on my mainframe PowerMac and it WORKED, both with local sound, and with the Fireface 400. So it seems there is a problem between PT9 and MacBook. Is anybody experiencing the same difficulty on a MacBook? Thanks a lot in advance. Marco |
The problem was solved!
I found that in the Playback Engine Window, if one UNCHECKS the Minimize Additional (I/O Latency)n box, PT starts again to play and produce sound. I do not know why (this is normally done when the computer is old, says the Doc, which is obviously not my case), this is probably a bug, but it works! Hope I will understand one day why...! |
2010-2012 Mac Pros, Imacs, and Macbook Pros do multi-channel HDMI audio out! | nst7 | Post - Surround - Video | 3 | 07-15-2013 04:37 PM |
image/editing pro to audio pros : hdcam max levels & what can go wrong with sound ? | charbon | Post - Surround - Video | 6 | 02-08-2012 01:54 PM |
Making Pro Tools LE sound like the Pros did it? | Dan M. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 09-13-2004 01:19 PM |
Live Sound Pros: HELP (about snake sends) | spicyitaliano | Pro Tools TDM Systems (Mac) | 3 | 12-27-2003 10:49 PM |
Powerbook Sound In | Tupelo | Pro Tools TDM Systems (Mac) | 1 | 10-26-1999 11:08 PM |
