Old 11-06-2004, 04:51 PM
Andi R Andi R is offline
Default templates
Hi all,
is this way of working with templates correct (it´s working, but) or is there a easier way?
"Pro Tools users on Windows XP can also create and use session templates, though the process is slightly different.
Simply create the session template and save it.
Then, close the session, find the session's icon and right-click on it.
Next, navigate down to Properties. In the Properties window, check the "Read Only" box.
Now, copy this file to a new folder, name it after the new project, and save it. uncheck the "Read Only" box before saving!.
Then, the next time you open the new session you can create your session as usual.
When you're done, save the session. Like this, all audio, fade, and other folder will be saved in the sessions folder."
the thing is, u need to have all data in the correct folder, so I guess thats the best way to handle it?
cheers, Andi
ReRecording Mixer & Venue D-Show Live Sound & Recording Engineer
www.audio-machinery.com
Old 11-06-2004, 05:06 PM
Bazzle Bazzle is offline
Default Re: templates
Once you have saved the new session, all subsequent data will be saved in that sessions folder.So you are good to go.
Bazzle
Old 11-09-2004, 01:11 AM
thanks, man!
Templates!!! juca2929 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-24-2008 01:44 PM
Templates Brad Newman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-19-2007 05:58 PM
templates in PT7 8thnote Pro Tools TDM Systems (Mac) 4 05-16-2006 12:40 PM
Templates BenTerry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-13-2004 08:37 AM
OMF bug using templates !! Helgonet Pro Tools TDM Systems (Mac) 8 12-10-2003 03:56 PM
