Old 02-19-2007, 07:52 AM
Denes Pagan Denes  Pagan is offline
Default Bypassing mbox preamps
Can anyone tell me once and for all if the focusrite preamps can be bypassed on the original mbox for sure?
I've a nice Avalon 737sp which I'm routing thru a Berinhger mini mixer in the meantime, which in turn goes out to the 1/4 line ins of the neutrix ins 1&2 of my original mbox. So far my ears tell me "no problems", but I wanna make sure that I'm bypassing the mbox preamps.
Of course there are a couple of other threads discussing this matter but I have not read one that answers the question without a doubt.
Digi, can you clarify this for me?
Old 02-19-2007, 08:17 AM
whitecat whitecat is offline
Default Re: Bypassing mbox preamps
yes, if the input selector is set to 'line,' you are not using the preamps at all.
you are not bypassing the analogue stage, that is, the signal is still going through the components to get to the AD conversion but the preamps are having no effect on the signal.
Old 02-19-2007, 09:55 AM
therecordinghouse therecordinghouse is offline
the ORIGINAL mbox has trs inserts. you will need to use these in order to truely bypass the pre. buy an insert cable, plug in the the mbox, then plug the "ring" in to the avalon. the mbox 2, however, does not have the option to totally bypass the pre.
btw, why would you send your avalon through the behringer mixer first, then in to the mbox? if it is for monitoring, why not just use a split cable out of the avalon? one goes to mixer for monitoring, the other to the mbox input. are you aware that the mbox has zero latency monitoring built in via the "mix" knob?
Lynn Graber
Studio and Mobile Recording, Fort Wayne, IN.
bypassing mbox 3 preamps Lonefse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-17-2011 05:21 PM
Bypassing mbox preamps brian4411 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-02-2008 10:19 PM
Bypassing mbox preamps Denes Pagan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-19-2007 07:52 AM
Bypassing MBox preamps - direct in Ian-H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-25-2006 05:16 AM
bypassing preamps on mbox Rod Elledge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-30-2004 07:59 PM
