Pro Tools 12 HDX latency Issues -Please Help
I am ready to quit Pro tools ..I am giving up
Bought this HDX system that have more issues than any other Pro tools system I had My TDM accell 3 was rock solid WHILE MIXING : I get now random latency issues, some plug ins create huge delay problems. They can be reflected in individual tracks as also for example having my HW effx via AES to sound so late. all the issues seems to be random. also pretty often the whole session get a huge latency issue in most tracks..so I have to change the Buffer Size and then sound ok again... also Sessions take between 2-5 mins to load....way longer than with my old TDM system. I have no idea what can be I use a mac 10.10.5 Pro Tools 12.5.2 32 GB of RAM Mac HD is a SSD and using other Hardrives for audio. I have no idea how to solve this problem and many of the Avid Tech can not help at all after reading all the issues around...I think i have to move to a professional solution... because I can not rely my work in such a unstable system
Thanks! Reuven Amiel Mixer/Producer. Last edited by AMIEL; 10-22-2016 at 03:35 PM. |
Re: Pro Tools 12 HDX latency Issues -Please Help
cheers john
Hi John,
Thanks Is a Mac Pro Mid 2012 2x 2.4 Ghz 6 Core Intel Xeon 32 GB of RAM Graphic Card: ATI Radeon HD 5770 1024 MB with the same Mac with my TDM accell 3 system was working great... also I was in Mountain Lion can be Yosemite the big issue??
Thanks! Reuven Amiel Mixer/Producer. |
Mhhh. It's weird. I am on HDX since 2 years or more, and it's always been rock solid. I had a TDM HD3 accel rig for 8 years before that and in the last year ofmthe TDM rig, it was a pita! Always to the limit of the system, DSP shuffling, lack of voices, instability using native withnTDM, etc... My HDX rig solved all these problems and gave a new life to my mac! I hope you will be able to solve your issue because honestly, HDX is a great solution,,way better than TDM imho. I am on HD 11. I am testing 12.6 right now, and it seems solid too. I had good luck with maverick. And i installed 12.6 on maverick too. |
I have no idea what it is...
Just changed a MacOS HD with Maverick 10.9.3 .. same issue
...maybe check proper seating of the card and cables....
my hdx card made also problems until i changed the pcie slot , the fixation of slot 2 for pcie cards in mac pro (at least in my MP 4.1) is BAD , because there is no screw to keep the card , better try an other slot .... did you tried digitest? regards
foley artist , soundeditor |
Did u try reinstalling or may be trashing the preferences.Try loading the session without any plugins
Likely one (or more) plugins causing issues - you might try narrowing it down by running with a basic set. I've had these kinds of issues with certain manufacturer's plugs (which I now avoid).
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Just to check in - how did you go from HD to HDX? New clean install or "update"?
IME a solid PT system (Vanilla HD or now HDX) starts with a clean OS install (on a clean system drive) followed by a clean PT install. Then download the current version of every plugin installer you are going to use. For an HDX system - start with AAX-DSP only. I suggest AVID only to start. There are many longtime very stable vendors as well (MCDSP, Metric Halo, Sonnox, SoftTube etc). Add these next but only one at a time (or one bundle at a time) to start. Test everything. Then add trusted Native vendors - sadly again one at a time (or bundle at a time) to be sure. Waves, Fabfilter, and Plugin alliance have all been very solid for me. Lastly - make sure that no send or return on aux tracks (especially unused ones) has an undefined input or output. I have endless weird delay comp scenarios when this happens. A session restart is often needed. I have setup and used many PT systems and this has always been the process. HDX works fantastic at what it does. But when going from HD to HDX there is a ton of plugins that have to be just left behind.
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
I will try another PCIe Slot now,
I Tried 3 different Hardrives with 3 Different MacOS Mountain Lion, Mavericks and Yosemite and all have same issues, Also, is not about 1 bad plug ins... is about many different plug ins adding latency and weirdness,
Latency issues (pro tools and control panel show different values...) | birdfluvirus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-24-2012 10:22 PM |
Latency Issues - changing latency has no effect | Kippa-Dee | Pro Tools M-Powered (Win) | 1 | 07-15-2010 08:39 PM |
Latency issues - Pro Tools and Roland TD10 | bcenza20 | The Drum Room | 0 | 06-15-2010 10:29 AM |
Monitoring Latency issues 001 and Pro-Tools 6.4 LE | eastwood1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 08-30-2006 01:04 AM |
Pro Tools LATENCY PROBLEMS!! Issues anyone????? | rselly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-07-2006 04:01 AM |
