Pro Tools Ultimate 2023.6 - Long duration session recording
Would anyone please confirm that PT Ultimate support long duration multitracks recording ?
I plan to bring my PT rig to video taping session ( around 8 hours straight) and would like to confirm that PT Ultimate support wav 64. Leo |
Re: Pro Tools Ultimate 2023.6 - Long duration session recording
I had 2 absolutely identical Macs (trashcan) with identical installation. The same HDX2 system recorded 24h several times without any problems on the first Mac. On the second I got a freece within 10 minutes up to 5-6h. PT can do this, if your Mac/PC let you do this...
www.srs-mastering.de Mac Pro 6.1-8core, OS 12.6, PT2023, HDX2, Sonnet Echo Express III-R, Madi Interface. |
You are a way braver person than me. I'd be looking at a field recorder (and I have SoundDevices MixPre units, but I'd test them as well continuously for as many hours as needed) or a digital rack recorder (like a ProCo).
I'd rather trust a field recorder or JoeCo style box first.
If I had to use a DAW, I'd use Reaper. As well as being more stable than PT, it will write to two disks simultaneously and it's not complicated to do so. Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon. |
Avid include the following, unreassuring section in the release notes of 2023.6.........(https://resources.avid.com/SupportFi...ead_Me-Mac.pdf) (advice has been consistent for over a year).
"Enable Spotlight for best performance when relinking files and indexing in the Workspace (PTSW-183818) For best performance with relinking and Workspace indexing, enable Spotlight. While enabling Spotlight is not required, it will improve performance in this area with Pro Tools. When Spotlight is enabled, long record passes (over 50 minutes) may stop recordings after 50+ minutes. Consider disabling Spotlight for long recording sessions and then re-enable it when you are done recording". So, Spotlight on, but Spotlight off. Might ruin your recording...... Dominic
As far as I know, Pro Tools does not record in Wav64 or RF64
Reaper supports WAV64, RF64 and BW64.
It will either auto change format if the file gets too big, or you can force the format for the session from the outset, in the Project Settings dialog, under "Large Files". Dominic
+1 for a dedicated field recorder like JoeCo. You'll need to run a backup recorder anyway. Right? Never do this kind of gig without a backup.
~Will |
Personally, as someone who uses Pro Tools every day (currently on a session with a stripped back HDX rig which still occasionally drops out of record), I would very strongly suggest you look at another DAW like Reaper.
I've never had Reaper drop out of record even on some janky computers. Absurdly stable. Pro Tools is great but in no way would I consider it the most stable 'tape machine', if anything it's the least reliable of the major DAWs. |
I agree with above comments. Using PT for on-location gigs is a bit risky. (Having said that, I've been doing it for years. In my case however, I only need a basic rig for easy/basic/low-track-count remotes.)
for long PT recordings: AC power conditioner PT rig fully optimized, incl all plugs compatible Disk cache (If possible for your session) use a large buffer (If possible for your session) don't touch PT while recording Thoroughly test the rig before the session, power down, test again
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
PT Ultimate 2023.6 hd driver bug | kinghand | Pro Tools HDX & HD Native Systems (Mac) | 59 | 09-27-2023 05:27 AM |
Issue with transport setting on Ultimate 2023.3.0 | Zarabozo | Pro Tools | 3 | 06-08-2023 11:12 AM |
Upgrading to Ultimate, cuts annual plan duration to half! | Akiz | Licensing & Accounts | 12 | 03-12-2020 06:13 PM |
When importing a long duration mp3 Pro tools insert an audio in the end of the file | georgenahssen | macOS | 0 | 03-07-2018 07:35 AM |
Pro Tools session duration limit? | fizzler | Pro Tools M-Powered (Mac) | 5 | 06-17-2008 01:07 AM |
