ElastiquePro
What does ElastiquePro do? If anyone cares to explain? It's an option enlisted under the elastic audio plugins? (Polyphonic, Rhythmic, Monophonic, Varispeed, X-Form etc). I know what the others do.
Confused as to what X-Form and Varispeed do as well, a little bit.
Take care brush your hair, Rey https://r-e-y.com/ macOS Ventura Pro Tools 2022 iMac (Retina 5K. 27-Inch, 2020) Processor 3.6 GHz 10-Core Intel Core i9 3.6 GHz Dual-Intel Core i7 16GB ram AMD Radeon Pro 5700 8GB Shure SM7B Mic Pro Tools | Carbon Komplete Kontrol M32 AKAI Mpk3 Mini KALI Lp 6 (2) |
Re: ElastiquePro
It’s a different (and vastly better) third party time-stretch algorithm.
Guy Rowland www.guyrowland.co.uk www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music. PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i Macbook Air M2; 24gb RAM |
Re: ElastiquePro
Better than the standard algorithm, but how does it compare to X-Form?
Re: ElastiquePro
X-Form was the only rental plugin I used as part of my support plan for TC/E use. I didn’t think that was enough to justify keeping it up - feature improvements have been pretty poor of late - so I decided to hunt round for a replacement. Elastique beat it pretty comfortably. It’s a shame in 2023.3 they don’t allow the algorithm to be used for TC/E, I suppose at least I didn’t buy a license for nothing!
Re: ElastiquePro
So if you want it for TC/E you'll need the ElastiqueAAX audio suite plugin. They sell a version of the plugin for like $175 which will only let it be used with TC/E (and frankly that's what they should have let AVID have too, which would have given you what you wanted). The full ElastiqueAAX plugin with the AudioSuite GUI interface is like $350.
🖥️ Pro Tools Ultimate 2023.12.1 | Mac Studio M1 Max (64 GB) | Ventura 13.5.2 | Focusrite Red 4Pre 💻 Pro Tools Ultimate 2024.3.1 | MacBook Pro M3 Pro (18 GB) | Sonoma 14.4.1 |
Re: ElastiquePro
In my experience using Elastiqúe Pro, it gets SUPER buggy when you commit the audio. Strange audio blips, audio not being in the right place as when you edited it, etc. Renders it utterly useless at the moment. The plugin is outstanding, the algorithm as it has been incorporated into Elastic is not ready for prime time yet.
M |
Re: ElastiquePro
I have just updated pro tools for the use of elastique pro. I love the sound but when I go to bounce in place (alt shift 3) it reverts my editing back. When I commit (right click on track and commit and make inactive) it shifts everything I've done. same thing if I try to record it to an audio track. What gives?!?
We finally have an algorithm that sound good and I can't even bounce it down? Anyone else? |
Re: ElastiquePro
I tried rendering it and the waveform shifted out of time. When I changed the algorhythm to the other ones (such as Rhythmic) the problems went away and everything played back perfectly. If I rendered with Rhythmic, it was just fine. So something is definitely messed up with the timing of ElastiquePro. I'm not sure why it gave me a problem on this track, but not on others. I'm still researching.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
Re: ElastiquePro
I'm glad I'm not the only one. It sounds sooooo good, but it's useless. Even on playback, it starts drifting after a few bars.
Such a bummer. |
Re: ElastiquePro
I concur with the above. It seems to run fine when it's "real-time", and for me it seems fine with "standard" use, but it definitely struggles with keeping the timing faithful when it comes to committing if there are tempo changes, or if you've e.g. generally sped the whole track up. I've even had it "wobble" up a semitone for a small section. I've definitely had that thing where it's gone out of time by the end of the track when its been "committed", I actually thought I was going mad at first as I couldn't believe it wouldn't just work.
I've also found that, although it IS on the whole the best sounding (when it's working correctly haha), it still has a tendency to smear the transients a little, compared to Polyphonic (although Poly has its own inherent problems of course). TL;DR In the main I've stopped using it as I just don't trust it. |
