Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 05-02-2016, 12:32 PM
laori laori is offline
Default How to keep timeline selection using "back and play"
Hello,
I almost find the perfect way for me to work in theatrical dub mixing.
but:
I want to be able to keep a timeline selection while I use "back and play" control (transport). "back" and "forward" does it, "back and play" not ! (right rick on backward, or s5 and Icon control button makes the selection disappear also)
Really annoying !
I use "dynamic playback" which is great for having "Play Start Marker " moving inside the timeline selection, except with "back&play"... timeline selection lost...
Link timeline to edit selection is unchecked (which is what I want for quick edit without lose my timeline selection).
Why can't I use "back&play" without loosing my timeline selection ???
Thanks for telling me !
Have a good day !
Laori
Old 05-19-2016, 12:42 AM
tamasdragon tamasdragon is offline
Default Re: How to keep timeline selection using "back and play"
Hi, just tried it, and if I unlink timeline and edit selection then it works great with back and play, timeline selection is preserved.
my blog:Tamas Dragon
Old 06-02-2016, 09:12 AM
joachim's Avatar
joachim joachim is offline
Originally Posted by tamasdragon View Post
... unlink timeline and edit selection then it works great with back and play, timeline selection is preserved.
Is the timeline selection really preserved ? It is changing to an Edit Selection in my case.
Case : linked edit/timeline , select clip , unlink edit/timeline , Start-clicking (Ctrl-clicking Mac) Rewind will make a timline-insertion and an edit selection and a back+play.
With automation, a possible write-to-all at this time will do the write-to-whole-session-thing.
In order to avoid this, one must first actively command "play edit selection" and then write-to-all.
Or, stop playback and command "Edit Selection To Timeline Selection" (O) , playback, write-to-all.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 11-07-2016, 07:31 AM
Hello there,
I'm back with... the same question... and some Gifs.
So, assuming I want to be able to write some automation in "to end" mode but only in a selected area (timeline selection). Everything works fine with dynamic transport which allows me to have both edit selection and boundaries to my automation untill I press "back and play", which is so convenient...
the 3 first Gifs
And the problem occurs with "back and play": 4th Gif
Any ideas ?
Thanks !
Edit: animated gifs should coming soon... newbie mistake
Old 11-07-2016, 07:38 AM
Sorry for the still Gifs,
here are the animated ones:
http://imgur.com/aAsSn5n
http://imgur.com/nXUXFnT
http://imgur.com/SyNEdRt
http://imgur.com/CQnJMcx
Old 11-07-2016, 07:59 AM
All in one: http://imgur.com/a/RV6lV
Old 12-04-2016, 06:26 AM
Hello ! Am I alone with this issue ?
Old 12-10-2016, 12:21 AM
I will check it on monday.
Old 12-12-2016, 04:46 AM
You are absolutely right. There's seems to be no way to keep the selection with back+play. I don't know if this is intentional, but guess it's not.
Old 12-12-2016, 05:14 AM
Stig Eliassen's Avatar
Only thing I can think of is to use Cmd+Opt+Left arrow in combination with suitable pre- and post-roll values to keep the selection.
"Play Selection" Overshoots blastula Pro Tools 12 5 01-25-2016 06:09 PM
is "Back and Play" command possible w/Transport nedd Artist Series 5 03-23-2013 03:18 AM
Pro Tools 9 "Pausing" when I press "Play" with Focusrite Scarlett interface eanderso22304 macOS 3 11-23-2011 06:45 AM
"play from end of selection" and "play until end of selection" innenhofstudios macOS 4 06-22-2011 08:45 AM
If I "Remove Unused Regions" after "Consolidate", track won't play? el biciclista Pro Tools TDM Systems (Mac) 10 04-02-2003 10:17 AM
