Old 02-14-2017, 10:33 PM
Electronic1982 Electronic1982 is offline
Default Avid's plugin Menu organization is worse than...
Old 02-14-2017, 11:54 PM
PTlanceK PTlanceK is offline
Default Re: Avid's plugin Menu organization is worse than...
I have no issues with it. In preferences you can put Manufacturer and category
Old 02-15-2017, 12:05 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Only thing I would change is to have the option to view the lot at once. Sometimes I have some native plugs that are not dsp (surely not? &#129313 and it can be a bit hard to find some. Viewing the lot would make "happy accidents" of rediscovery more likely.
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 02-15-2017, 01:01 AM
Only thing that bugs me is that I need to remember first whether the plugin is stereo or multi-mono. If a plugin is mono-only, it will not appear on the stereo list for obvious reasons. Many times I don't find (fast enough) what I think I'm looking for and therefore end up using something else.
I myself would drop that and show plugins first, then different version (multi-mono, stereo, dsp multi-mono, dsp stereo) of plugin when I hover over the plugin name.
Old 02-15-2017, 02:30 AM
tamasdragon tamasdragon is offline
Actually I like it, the only thing I'd change is to have a custom or favourite menu so I can choose the most used ones, let's say 10 or so.
my blog:Tamas Dragon
Old 02-15-2017, 03:24 AM
cut cut is offline
This one is low on the list me thinks.
Old 02-15-2017, 03:48 AM
Drew Mazurek's Avatar
Hold down Command while inserting a plugin and it'll be made a "favorite" and appear at the top of the list next time you go to the pulldown.
www.drewmazurek.com
Old 02-15-2017, 03:50 AM
I know that one, but that's only one or two. I'd rather compile a list tailored to my needs, including EQ, DYN, some special processing, etc.
Old 02-15-2017, 03:59 AM
I literally have no problem with it at all. Just move unused plug-ins to the unused folder. Sorted.
Old 02-15-2017, 04:02 AM
Meads Meads is offline
How about a little searchbar on top or bottom of the dropdown menu? That would make me happy.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
pro tools plugin menu, and options menu blank lucidlife Pro Tools 10 4 12-07-2014 12:16 AM
plugin organization WilliamDC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-09-2006 09:10 AM
Plug-in Menu Re-organization Bluefish Pro Tools TDM Systems (Mac) 4 03-09-2005 07:12 AM
Wrong Plug-in menu organization in PT 6.4!!!!! PIRULO Pro Tools TDM Systems (Mac) 5 05-02-2004 12:24 AM
Plugin organization? cali316 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-22-2004 06:24 AM
