Old 10-26-2022, 03:38 PM
legacygt777 legacygt777 is offline
Default Artist Mix Stop Working in Pro Tools
I am using Windows 10. I have both the Artist Mix and Transport.
These two have been working for years despite the changes in Pro Tools. I have the latest Pro Tools from 6mos ago.
My Artist Mix and Transport are being identified in Eucon. I was on Eucon 3.1. In Pro Tools, I click on Eucon search and it said that the "Eucon personality could not be loaded because of the wrong version is installed. Please install version 3.2 or higher..."
I uninstalled the old Eucon and installed the 3.2. Eucon is identifying my artist hardware and I updated the firmware, but now it says "access violation occurred, unable to read location: 0x000000000000000008"
It stays in this loop and I have to shut down Pro Tools. I've never had this problem. I'm not sure which Eucon version to download or what I'm doing wrong.
I would appreciate any help. This is really frustrating. I'm not really good at these kind of issues.
Thanks again.
Old 10-26-2022, 04:25 PM
Default Re: Artist Mix Stop Working in Pro Tools
Its tough to offer help with nearly zero information about the setup
Old 10-26-2022, 04:46 PM
My Setup:
Lenovo S20 Workstation
[email protected]
SSD 500GB
20gig ram
Nvidea 1030GT
Windows 10
Eleven Rack
Mbox Pro 3
Artist Mix
Artist Transport
PRO TOOLS 2022.9
Eucon 3.2
If there's something I'm missing, let me know. Thanks.
Old 10-26-2022, 08:15 PM
I figured it out. I uninstalled everything and installed Eucon 18.3.
Old 10-27-2022, 09:31 AM
EddieJones's Avatar
Why are you installing all these old versions? Just install the latest 22.9
Old 10-29-2022, 10:15 AM
Does Eucon 22.9 update the Artist Series? I didn't see any updates regarding the Artist Series.
Old 10-30-2022, 11:46 AM
EddieJones's Avatar
Yes
Old 11-03-2022, 11:48 AM
Ben Jenssen's Avatar
I hope it's OK that I throw my own issue into this thread.
Suddenly today, My artist mix won't connect. It doesn't show up in Eucontrol surfaces. I've checked cables and connections, installed Eucontrol 22.9 again, and can not see that anything has changed since yesterday that could be causing this. My ipad connects.
Most importantly; when I turn on and off the power button on the top right of the artist mix, it lights up, then shows the AVID logo on the eight displays, then nothing. The normal fader movement, where all faders move quickly up and down never happens. I hope it's not broken.
Old 11-03-2022, 12:21 PM
EddieJones's Avatar
Did you pull the power lead and try?
Old 11-03-2022, 12:32 PM
Yes, I did.
But I just found the cause; earlier today I noticed in the system settings, network, there was "USB 10/100 LAN" enabled, and I thought 'I don't have Ethernet over USB' so I turned it off. Now I have enabled it again, and it's back to normal. Artist Mix working like before.
Sorry for wasting your time.
Stupid me.
Might help someone else doing this, like I did, though.
(Added: My Artist Mix is connected to a USB-C dock. I guess Eucontrol enabled this network setting automatically when I first got the controller last spring, and I just didn't notice before. Or I'm getting to old to remember.)
Sends stop working if I press stop/play too fast.. 12.4 thierryhenry Pro Tools 12 0 12-21-2016 03:26 PM
Pro Tools causes gestures to stop working DJ Hellfire macOS 1 07-14-2015 02:36 PM
Pro Tools 11 stop working error Natanel Arnson Pro Tools 11 4 10-29-2014 03:32 PM
pro tools stop working even with low system usage [email protected] Windows 3 12-30-2012 01:40 PM
Pro Tools Plug-ins STOP Working KyleThompson2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-12-2006 04:00 PM
