Old 06-18-2021, 05:20 PM
johnlackner johnlackner is offline
Default Protools "locks out" all other audio on computer
when I open Pro Tools I am unable to listen to any other audio on my computer -clips, music, etc. is there a setting to fix this?
Old 06-19-2021, 04:42 AM
Default Re: Protools "locks out" all other audio on computer
How about some system info please? If Windows then you'll want to assign systems sounds, etc to an audio card separate from the audio interface you're using for PT. Windows doesn't like to share the audio card amongst applications at the same time.
Old 06-19-2021, 08:35 AM
What he said^^^ This has been Windows protocol for 99% of us forever. Have an interface for Pro Tools and let everything else playback thru the on-board sound card. Now, I'm sure you want to hear everything thru your studio monitors and there are a couple of ways to do that, depending on your needs and your budget.
#1-the simple and cheap method: buy a small mixer(Behringer, Alto, Alesis, etc for around $50) that has 2 stereo channels. Patch in the outputs of the interface and computer sound card and you're done. Advantage; you can listen to both sources together.
#2-Better but more expensive: add a monitor/source selector(Mackie Big Knob, Presonus Monitor Station 2, Audient Nero, etc; $150-499). Advantage; You can add more sources(iPhone connector, Bluetooth adapter) and more speakers(maybe with a sub) so you can expand your listening options(always good to check mixes on several sets of speakers). A possible added advantage: if your computer has a digital output(mine has optical SPDIF out), using that(if the switcher has the proper inputs) will seriously improve the sonic quality of the computer's sound(the mini-TRS outputs are often a bit noisy and have limited bandwidth due to cheap converters)
"Unable to find an Audio Interface..." - fine after computer restart. A Chapman Pro Tools HDX & HD Native Systems (Mac) 4 04-14-2021 04:42 PM
"Digidesign Midi I/О" in "ProTools 10HD" in "OSX Maverics" electra1006 MIDI 0 06-18-2018 05:46 AM
Protools LE 8 hang while "setting up peripherals" and while "loading tracks" xfarre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-22-2011 07:37 AM
Is my 11R linked to "this" computer for "life"? (Answer: No, not really) blewis Eleven Rack 6 03-29-2011 01:54 PM
MLCD Locks at writing "Lead Out" El Guapo Digidesign Hardware & Software 2 09-21-2001 04:14 PM
