Old 12-13-2002, 01:08 PM
Guest
Posts: n/a
Default VARI-FI + PT5.1.1+dp 867
Hi
after installing and authorising D-FI , the VARI-FI plugin doesn´t appear in the plugin menu. PT says during startup that it is loaded.
SCI-FI, RECTI-FI and LO-FI are working as usual. Does anybody know this problem
Next , worse problem. My waves key(2.8.1) isn´t recognized from wavekey utility. I use iMATE adapter for ADB to USB(driver 2.7) So no using of waves plugs. Instead, logic key is
recognized without any problem !
Thanks
Old 12-13-2002, 01:57 PM
mm mm is offline
Default Re: VARI-FI + PT5.1.1+dp 867
You do know that Vari-Fi will only show in the Audio Suite plugins menu.
Old 12-14-2002, 11:56 AM
Extreme Mixing Extreme Mixing is offline
I think you need a newer version of Waves to run with 5.1.1--3.0 or maybe even 3.2.
Steve Shepherd
Extreme Mixing
New Vari-Fi necjamc Windows 20 09-25-2012 04:57 PM
New vari fi lilreal Pro Tools 10 1 04-22-2012 08:45 AM
Vari-Fi A Chapman macOS 0 01-05-2012 05:29 AM
Vari-Fi The Tao Of Chris 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-03-2011 09:37 PM
vari-fi tomcat Tips & Tricks 0 08-22-2000 06:11 PM
