Go Back   Avid Pro Audio Community > Pro Tools Hardware > MBOX Studio
Old 11-30-2022, 01:36 PM
basslik's Avatar
basslik basslik is offline
Default Mbox SPDIF/adat switch ?
Hello all you great folks,
This holiday I'm finally going to upgrade my interface. Narrowed down to the EVO16 or the new Mbox Studio.
The EVO has no midi, not liking for that.
Just watched Mitch Gallagher doing an overview of the new Mbox and from what he is stating you can switch between SDIPF or Adat connection.
Currently I able to run simultaneously 8 channels of Adat and 2 channls of SPDIF. A total of 18 channels through the DIGI 003.
Can someone clarify if you can run both on the new Mbox, SPDIF & Adat together ?, thank you.
Also, Jeffro, many thanks for helping me resolve an issue.
MAC PRO 2010 5,1 3.46hex 128ram - MOJAVE 10.14.6 - PT 2022.7 / 003 CONSOLE / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Old 11-30-2022, 02:44 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Mbox SPDIF/adat switch ?
Yes to both... avid.com/products/mbox-studio/specifications lists Optical (ADAT or S/PDIF) and Coax (S/PDIF), plus MBOX Control shows both in Hardware Input and Hardware Output.
File Type: jpg Screen Shot 2022-11-30 at 2.42.29 PM.jpg (41.8 KB, 0 views)
Old 12-04-2022, 09:46 AM
Ob1clyde Ob1clyde is offline
Im trying to set up the Mbox studio as the main interface.When connecting my Fractal axefx 3 via spdif I get no signal. I take the same cable use a spdif/coaxial converter and then run the signal into the optical in and it works just fine. I did need to set the word clock to the fractal but thats pretty standard to eliminate pops.
Why is it the direct cable spdif out of fractal to spdif in on mbox does not work?
This spdif input was another reason i chose this unit as my old Apollo twin only had the optical input and why i actually have the converter on hand to test this.
Old 12-28-2022, 09:40 AM
basslik's Avatar
You ever get it resolved ?
Old 01-03-2023, 11:19 AM
Yes, for some reason instead of selecting the spdif as the source in the settings menu.. it works by selecting ADAT. Now if I ever need to expand and actually use both.. who knows. But for now my
System is working well.
HELP PLEASE?!! Powerbook? MBOX?? ADAT?? SPDIF?? jkung 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-21-2005 02:53 AM
SPDIF to ADAT Percustard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-09-2004 07:42 PM
Switch Mac Mbox to Windows - and then switch back bluesigns 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-07-2004 09:50 AM
Adat/BRC/AI-1 to Mbox SPDIF anyone? John J. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-23-2002 12:28 AM
cannot switch adat to opt spdif yoz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-16-2000 04:49 PM
