SPDIF to ADAT
Can an optical SPDIF cable be plugged into and the ADAT light pipe on 001 and be recognised by protools?
Re: SPDIF to ADAT
Sure can. There's a setting in the preferences to change the optical I/O from ADAT to S/Pdif.
But note that this disables the Coax I/O. The two won't run together.
http://www.oneearthproductions.net |
Re: SPDIF to ADAT
Just to clarify: the optical and the coax CAN run at the same time, but S/PDIF can only be on one or the other.
Quad 2.5 G5, 4.5G RAM |
Re: SPDIF to ADAT
Thanks Aussie and Tele....much appreciated.
In Setups/Hardware/other options/Optical format...I get a greyed out box. I can see the word ADAT with an arrow next to it (I assume the arrow allows you to select SPDIF) but its greyed out so I cant select anything in the Optical Format box. Any tips on why this is so. I hope to hear from you soon. Mark |
Re: SPDIF to ADAT
A further question:
How do you determine which is SPDIF input and which is SPDIF output on the 001 PCI card? And... Are optical spdif cables available in different lengths? Thanks again. Mark |
Re: SPDIF to ADAT
Percustard ,
If it doesn't say In or Out beside the ports...the one which glows red is the output ... Quote:
happy tooling,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Adat/spdif | jeremy1230 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-05-2010 09:35 AM |
ADAT or SPDIF | mrblakemr | Tips & Tricks | 1 | 07-04-2006 02:34 AM |
Adat or spdif | BookSix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-13-2005 01:42 PM |
SPDIF and ADAT | sikblades | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-15-2005 09:03 AM |
ADAT or SPDIF | godscent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-07-2004 10:29 AM |
