Running Pro Tools 2021.10 on Mojave 10.14.6
Has anyone installed Running Pro Tools 2021.10 on Mojave 10.14.6? If so, any issues? Thanks.
ProTools 2021.12, Lynx Aurora (n) 32 TB, Sibelius 23.2.0; OSX 10.14.6; Mac Mini: 3.2 GHz Intel Core i7; 64 GB 2667 MHz DDR4; Internal 2 TB SSD, External Sabrent TB 2 TB SSD Also ProTools 2021.12, 002R,; Mac Pro: 2 x 3.46 GHz 6-Core Intel Xeon; 128 GB 1333 MHz DDR3 ECC; Serial ATA Drives (Journaled HFS+): 2 x OWC Mercury Electra 3G 2 TB SSD; 3 x Seagate Barracudas 1.0 TB; External Firewire Drives (Journaled HFS+): 4 x Seagate Barracudas 1.5 TB and 6 x Seagate Barracudas 1.0 TB |
Re: Running Pro Tools 2021.10 on Mojave 10.14.6
I am.
So far it's been much more stable than 2021.06. As I stated in another thread, I had previously reverted to 2020.09 due to UI freezing (beachballs). Happy to report no such issues on 2021.10 today. There's another thread describing an issue with VCA meters but I haven't touched VCAs since the introduction of Routing Folders so I can speak on that. |
Running smoothly on a 2018 MacMini (32gB RAM) so far.
Couple of weird GUI things like a muted send has a little white line through it but..maybe that's a featured request ? , not getting in the way of work, though. |
It is working. My Komplete Kontrol (S mk1) Transport keys don't work after setting it up (and confirming the drivers are all the latest), but the rest of it seems as functional as 2021.7, at least.
2009 Mac Pro (flashed to 5,1)
Kerry Smith http://apothekerry.com Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro |
Komplete kontrol mk1
Not supported … info kind of buried , as usual
Hal Cragin On the DUC Since The Year 2000 AD Ventura ,PT 2022.10, MacbookPro 13"[2020] M1 16G, Antelope Orion 32+ Gen3..SSL Sigma summing, SMART Comp C1LA, CharterOak EQP-1 Oceanway Audio HR4S monitors . SSL X-Rack w XR618 compressors, dbx 160x [2] |
Where IS it buried? Enquiring minds, and all.
Thanks for this update. I too am running a 2018 MacMini fully loaded. Are you running Mojave or other OS? Thanks.
I installed 2021.10 on our two Mac Pros both running 10.14.6.
Works fine in my edit suite with my Mbox Pro, no problems so far. But I get instant rainbow wheel crashes on my 2012 Mac Pro w 1 HDX card. I can safely say it's related to my ancient Neyrinck V-Mon DSP monitoring plugins. When I remove those plugins PT launches fine, but then I have no control over my digital Genelec speakers. For now I've copied Pro Tools 2021.7 back from my SuperDuper backup, and will use that until I find a replacement for V-Mon. (Long backstory I've contacted V-Mon support re: similar crashes before, but they said it's a Pro Tools problem, and AVID says nothing. High time to move to a supported monitoring solution.)
Control Room: PT Ultimate HDX 2023.3.0 // Mac Pro 2012 // Mojave 10.14.6 // BlackMagic DeckLink Intensity Pro // Genelec 5 x 8250A + 7270A DSP Active Subwoofer // Yamaha NS-10's Edit Suite: PT Ultimate 2023.12.1 // Mac Pro 2013 // Monterey 12.7.3 // Focusrite 18i20 // Genelec 5 x 6010A + 5040A Active Subwoofer Video Suite: PT Ultimate 2023.12.1 // iMac Pro 2017 //Monterey 12.7.3 // Focusrite Scarlett Solo |
I had never seen the Neyrinck V-Mon 3 until now. I like the interface but it is very pricey. I too have three sets of monitors including Genelec 8341 but I use hardware (Switch Witch) for monitor selection. If you find a good replacement for your Neyrinck please post back. Thanks.
How long will PT 2021 be compatible with Mojave | SweetSioeMusic | macOS | 8 | 09-01-2021 05:57 AM |
Audio tracks not playing when updating to 2021.6 (Mac OS Mojave) | jasonfarnham | Pro Tools | 1 | 07-22-2021 04:33 AM |
Saving Issues 2021.3.1 Ultimate Mojave 64gB ram | mrchristopher | Pro Tools | 5 | 04-29-2021 12:46 AM |
2021.3 and Mojave | bernstudios | Pro Tools | 19 | 04-12-2021 09:52 AM |
Anyone having issues with Security Update 2021-002 (Mojave) and PT 2020.12? | Cacov | Pro Tools 2020 | 3 | 02-28-2021 04:22 AM |
