Old 03-11-2019, 10:11 AM
legacygt777 legacygt777 is offline
Default windows 7 still works?
Hi everyone, I was wondering if anyone is running the latest pro tools with win 7?
I know it's not being supported but one of my laptops I've used for years runs smoothly with PT 10 and I don't want to change the OS.
Thanks for the feedback.
Old 03-11-2019, 11:33 AM
Default Re: windows 7 still works?
This is a great case for pulling the system drive and keeping it just as it is(IOW, working with PT10). Install a fresh SSD, load up Windows 10 and the latest version of PT(and the old drive becomes a very nice backup plan)
Old 03-11-2019, 01:11 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Yes it works with caveats: PT 12* must be installed first then 2018 can be installed over it with the old APP manager(i dont know if the new link manager will work). Also there are some graphics issues that are inherent esp noticeable when working in the mix window and dragging clips(the "waveform" disappears and/or appears below the actual track position. I just put the cursor where it's supposed to go and the clip ends up there , but it can be a bit annoying. I would actually recommend doing it the easy(second system drive)way explained above. SSDs for laptops are much cheaper than they used to be, and you really dont want to use a laptop spinner with PT anyway-I burned one up pretty quickly when i tried that back with PT 12.1.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 03-14-2019, 06:39 AM
daeron80 daeron80 is offline
This is what forced me to move from Win7 to Win10. Makes detailed editing slow and painful. Win10 is actually more convenient to use than 7.
David J. Finnamore
Old 03-14-2019, 10:44 AM
64GTOBOY's Avatar
To quote Phineas of Phineas and Ferb:"Yes, yes it does"
Old 03-14-2019, 01:23 PM
Or to quote that pirate meme guy, "Well, yes! But actually, no."
David J. Finnamore
Old 03-18-2019, 06:37 PM
TAMBOR TAMBOR is offline
You can leave PT10 installed and have PT11+ co-installed. You will have to install the 64 bit versions of all your plugins, of course.
Old 04-14-2019, 05:51 AM
Mr. Kelly Mr. Kelly is offline
Thank you, albee...
I am in the exact same scenario… I have a very old but failing system. I’m going to put in a new SSD, as a starter.
Would you be willing, in a nutshell, to say what you think works better with Windows 10?
I hear it is a resource hog. I wonder if that affects the performance while using PT?
Is there anywhere you can still get a free Findows 10 upgrade?
Old 04-14-2019, 08:22 AM
ValkRider ValkRider is offline
Quick search on web came up with this.
Use at your own discretion. Information was created in 2019
https://www.laptopmag.com/articles/u...indows-10-free
"So it goes", Kilgore Trout
Old 04-14-2019, 07:34 PM
Originally Posted by Mr. Kelly View Post
Thank you, albee...
I think that Win 10 is a leaner OS as compared to Win 7(YMMV). Since Win 7 is no longer well-supported, it just makes sense(to me) to bite the bullet and move forward. I know of no way to get Win 10 for free at this point, but I bought 2 authorizations off eBay sellers(with tons of positive feedback) and paid $50 for each(both authorizations worked here on 2 different PC's). You can download the installer from Microsoft(you can actually run it unregistered, but certain functions are not allowed until you register with a valid authorization code).
Protools 10 works in Windows 8 auratone Windows 6 10-11-2012 06:31 AM
MPK works in other OS, but not Windows on same computer flowetic MIDI 1 01-18-2012 06:44 AM
Does Protools works on 64bit Windows?? converted 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-14-2008 07:17 AM
PT7.4 Works fine, no sounds from windows though Darryl D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-01-2007 10:28 AM
TC Works for PT HD Windows wolftone Pro Tools TDM Systems (Win) 1 08-12-2002 09:58 AM
