Old 05-17-2021, 09:56 AM
Kerochan Kerochan is offline
Default why is loop playback intermittent?
Hi everyone
so, in Pro Tools 12.5, when I select a part of a clip and have loop mode in the transport some times it just plays through that section once and doesn't loop, other times it does, its kinda 50/50 chance of it looping, I can try once, no, try again yes!
Am I doing something wrong?
Any help appreciated.
Old 05-17-2021, 10:27 AM
Default Re: why is loop playback intermittent?
In answer to my own questions, seems there is a minimum length for loop play back.
Is this correct!?
Old 05-19-2021, 05:52 AM
That, and also, if any track is in Record-ready, loop play will not work
Old 05-19-2021, 08:02 AM
The Weed's Avatar
The Weed The Weed is offline
Or if "Insertion Follows Playback" is toggled on. Thank You "N" Key!
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Loop Playback in MIDI = Loop Record? saspro Pro Tools 2019 2 04-01-2020 07:06 PM
Intermittent playback mcfly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-14-2008 03:53 AM
Loop Record and Loop Playback will not engage? Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-28-2008 06:03 PM
loop playback intermittent jack9999 Pro Tools TDM Systems (Mac) 2 04-01-2007 04:24 PM
