Preparing for OSX/PT6
I'm going to use one of 6 SCSI HD (IBM 18G) exclusively for Mac OSX / PT6. My Mac (G4 867) internal HD drive will stay with OS 9.2.2 / PT 5.3 for now. Two questions :
- What should I use to format the new drive ? Apple drive setup, atto, or some OSX utility ? - Will I be able to boot from this disk with no problems (it's on one of the two channels of an Atto SCSI card) ? Thanks
http://www.stevegalante.com |
Re: Preparing for OSX/PT6
Steve:
I got this from the apple site. Hope this helps! Erasing and formatting your disk. When you install Mac OS X, you can erase the destination disk. In the “Select a Destination ” pane of the Installer, click the Options button. Select Erase and Install and then choose a format. In most cases, choose Mac OS Extended (HFS Plus). Be sure you have backed up your files before you erase the disk. To install Mac OS X on the same disk or disk partition as Mac OS 9, the disk must be in Mac OS Extended format. If it isn ’t, you need to erase the disk. You can also divide your hard disk into several partitions before you install Mac OS X. Choose Open Disk Utility from the Installer menu and click Partition. Partitioning the disk erases the entire hard disk, so be sure to back up your files first. IMPORTANT! Do not choose UNIX File System (UFS)as the format for the destination disk unless you need to work with this format. If you choose UNIX File System,you must install Mac OS 9 and your Mac OS 9 applications on a Mac OS Extended format disk to use them with the Classic Environment.
Dan Matthews InSight Sound Recording Loveland, CO (970) 663-1650 InSight Sound Web Page |
Preparing my system for HDX | garnoil | Pro Tools HDX & HD Native Systems (Mac) | 7 | 08-15-2013 08:16 AM |
Preparing for rapture! | DrFord | General Discussion | 9 | 05-22-2011 07:54 AM |
preparing for mixing | itai bn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-13-2005 11:25 AM |
Preparing to Upgrade to 6.4 from 5.3.1 LE 001 XP ? | R1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-25-2004 02:44 PM |
Preparing for wiring..... | SimonCPW | ProControl, Control|24, Command|8 | 0 | 07-26-2000 12:29 AM |
