Old 10-22-2009, 10:19 AM
Willie Myers Willie Myers is offline
Default External midi fader to track fader?
is there a simple "play-by-play" of routing an external midi fader (say, from a synth) to control an audio fader in the tracks window?
or is there none because it's not...."simple"!!
PTools 10.3.5, DigitalPerf 8.04, Sibelius 6.2,
Mac OS 10.8.4
MacPro 3,1 8core 2.8Ghz, 16 Gig RAM,
4 x 120Gig hds,
multiple LCDs
Presonus FireStudio Project, MTP AV
Old 10-22-2009, 01:56 PM
jmitchell1532 jmitchell1532 is offline
Default Re: External midi fader to track fader?
AFAIK, you can only control the faders in the Mix window with a Digi qualified Control Surface.
Jon
HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!)
Old 10-22-2009, 10:27 PM
djkiller djkiller is offline
yeah that's the only way i know of. i think you can control just rtas plugins with a midi solution like that in protools. i bought the digi002 board so i have it but honestly i use it here and there. i actually bought the digi002 for that and didn't really need 8 inputs but it was a good deal and an all in one. you can even get a digi002 all in one on ebay for like $700 or less.
Old 10-24-2009, 06:43 AM
accession accession is offline
Nah, it can be done, not simply if one's just wanting to rig up a fader on a synth, but there are ways.
Something like Novation's ReMOTE MIDI controllers, for example, come with a HUI template for full knob/button/slider/transport control of Pro Tools. This would be one of simplest non-Digi ways of doing it.
Old 10-25-2009, 05:54 PM
musicalavtech musicalavtech is offline
Try finding a used Peavey PC1600X. It has 16 faders + 16 buttons and a big knob. It has several presets for ProTools faders and plugins and then some. PT8.0.1 got the midi controller driver working again for it.
OSX10.6.8, 1st gen Power Mac,
PT8.0.5, Mbox2
10.3 and 10.3.1 Small Volume Fader AND Clip Gain Fader Problem Ale macOS 1 10-11-2012 10:07 AM
Basic Gain Structure Fader/Master Fader Question acmost Pro Tools TDM Systems (Mac) 1 05-16-2011 05:36 AM
Fader & Pan controls on MIDI track in PT8 new-b question Reesho 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-11-2010 07:44 PM
Midi Fader Volume - Instrument & Midi Track blizzard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-11-2010 09:35 AM
Adjusting fader/rec/sel/sol In midi track problem junkgem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-23-2006 06:42 PM
