Click track only clicks on the bar
After upgrading to the qualified 7.4.2 release, my click has been wonky. It only clicks on the bar, which really screws me up seeing as how I really only use it for count off. I looked around setup > click/countoff and setup > preferences and couldn't find a 'click resolution' option.
I trashed prefs and DDBs, repaired permissions and restarted and its still on the bar only. 10.5.3/7.4.2/Quad 2.66/2GB RAM/Mbox2 Pro (back firewire, no power unit) 500 int audio drive The session has reason 4.0 and is using rewire. If this is the culprit Im gonna be steamed. EDIT: well it just seems its that particular session. creating a new one (with rewire) has no problems with a click track. oh well.
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64 Focusrite Saffire Pro 40 / Pro Tools 9.0.3 Mics, Guitars, Amps, Basses, Drums, Keys http://overtheeffect.bandcamp.com |
Re: Click track only clicks on the bar
In the future, just change the click resolution - I get to it by double-clicking a tempo event in the ruler, but it's probably accessible from some other menu too.
thanks, that does *seem* to be what i was looking for, but no matter what value i change it to for this session, it still only clicks to whole notes.
You actually have to click on the meter event to change the click resolution. It's probably set to a whole note value (not sure why), but you can change that by opening the meter event window and setting another resolution. You can actually place tempo resolution changes throughout the track this way.
Avid can you please sort out the click track & Click 2 plugin | protoolsuserman | Pro Tools 11 | 14 | 11-14-2013 08:11 AM |
Click Track no longer clicks | halanrose | Virtual Instruments | 1 | 10-15-2013 01:08 PM |
Getting the click track to click at 16th notes... | broken81 | Tips & Tricks | 1 | 06-27-2008 07:06 PM |
Click Track - How to "UN" accent the click plugin | pepperbox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-02-2006 06:37 AM |
anyone else clicks like THIS? (click tracks) | VanGuard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-21-2005 04:21 PM |
