Old 01-16-2008, 08:11 AM
Paul David Paul David is offline
Default Soundreplacer and 7.4
I'm about to download soundreplacer but I noticed that it only lists the mac version at 7.3 and the PC at 7.4
http://www.digidesign.com/index.cfm?...00&itemid=1059
Is soundreplacer compatible with 7.4 on a mac?
Old 01-16-2008, 08:27 AM
Default Re: Soundreplacer and 7.4
I installed soundreplacer but It's only in the audiosuite list, not in the plug-in menu on the track I want to use it on.
Old 01-16-2008, 09:05 AM
DigiTechSupt's Avatar
That's because SoundReplacer is Audiosuite only.
Avid Audio Tech Support
Support FAQ
Old 01-16-2008, 09:39 AM
So there's no way to adjust the samples while hearing the track play? That seems like a lot of guesswork.
Old 01-16-2008, 11:58 AM
Phil Ogden Phil Ogden is offline
Not within the context of the mix. However, there is the preview facility which gives you a pretty good idea as to how the triggered samples will sound. Just deselect before making any adjustments to trigger thresholds, then re-engage. Works for me.
http://www.myspace.com/philogg
SoundReplacer Help! Stixntrixx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-02-2008 04:14 PM
SoundReplacer available for OSX??? ackerbone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-16-2004 12:23 PM
soundreplacer funkdoctor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-26-2002 04:54 PM
Soundreplacer... GW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 05-11-2002 10:05 AM
Soundreplacer and .aif bascani 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-02-2002 05:20 AM
