Old 06-27-2007, 03:43 PM
Iloopbari Iloopbari is offline
Default Pro Tools doesn\'t recognize M-Audio Hardware
I moved stuff around in my computer (Including the delta 44 interface.) and had to re-load the M-Audio software to get my sound working. Now Pro-Tools says it doesn't recognize the M-Audio hardware. How do I get things linked up again?
J. White, iloopbari
J. White
Old 06-27-2007, 09:40 PM
jfitz jfitz is offline
Default Re: Pro Tools doesn\'t recognize M-Audio Hardware
From my experience, Pro Tools likes to have hardware installed BEFORE it itself is installed.
This happened once with my delta 1010lt card a long while ago. here's what I did:
1)Uninstall Pro Tools using the add/remove programs utility located in the windows control panel.
2)Install the drivers for your hardware from your pro tools disc (or hardware disk) (even better is if you visit the m-audio site and make sure you have the latest drivers and install if you don't)
3)Re-install Pro Tools.
Hope that helps you.
Joe Fitz
Producer / Engineer
Old 06-28-2007, 12:40 PM
Thanks jfitz! That's kinda what I figured. I just thought I'd post for suggestions first to make sure. I'll post again after I re-install to let u know how I made out.
J. White
J. White
Old 06-29-2007, 03:03 AM
abre abre is offline
It does not see the driver at first installation. You have to navigate to the driver section in the control panel, click update driver and it would search and find it. I have seen this on many occasions.
ProTools SE 8.0.3 and MobilePre by M-Audio Won't Recognize hardware TommyInNashville Pro Tools SE and Essential (Win) 5 05-11-2013 07:28 AM
Pro Tools 9 won't recognize my hardware? Help!! :( mo246 Windows 2 02-12-2012 03:47 AM
Cant recognize M-Audio Hardware OneSickTexan MIDI 2 12-31-2011 10:25 AM
Pro Tools Doesn't Recognize M-Audio Hardware tytolliver Pro Tools M-Powered (Mac) 0 11-18-2010 11:04 AM
Pro Tools 8 does not recognize hardware shavedkitty69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-21-2009 03:07 AM
