Old 05-03-2005, 02:05 PM
FrothyG FrothyG is offline
Default Determining tempos
How do I determine the tempo of audio files in pro tools?
Old 05-03-2005, 02:29 PM
edytnbch edytnbch is offline
Default Re: Determining tempos
find the points in the wave file from a four beat measure, and use Identify beat. pro tools will automatically create a tempo map for the entire song based on your selection.
Old 05-03-2005, 02:32 PM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
'tab to transient' often works very well to find the beats in an audio file. Then identify beat as explained to create a tempo map. If the tempo 'floats' identifying every bar might be a good thing.
Chris Lambrechts
Applications Specialist- Live Sound
Old 05-03-2005, 02:57 PM
subskin subskin is offline
Depends on the tune - but sometimes after identifying the beat - I use Beat detective's "measure" setting to create a relatively stable tempo map - even if the tune drifts a bit midi events and subsequent loops will stay nicely in time...
Subject51
Producer / Composer / Remixer
Old 05-04-2005, 05:21 AM
Do I just highlight the 4 beats then use Identify beat? When I use idenitfy beat what do I type in the fields, or should I leave them the same?
Old 05-05-2005, 08:50 AM
Monte McGuire Monte McGuire is offline
You type in the bar and beat number that corresponds with that point in time. If you leave the fields the same, you're just "cementing down" the existing tempo map without considering what is actually happening in your recording.
Example: let's say you're mixing a reggae song and there's a solid snare on beat three of every measure. This would be a good choice to use as a tempo reference. Click on the snare track, tab to one of those beat 3 snare hits, type command i and then type in what measure number you're at and what beat you have (beat 3 in this case). You'll probably have to count a bit and make a decision as to where measure 1 should be to decide what measure number you're dealing with. Identify more and more beat 3 snare hits and you'll have a more accurate tempo map. If you're running a sequencer with PT then you probably want a really accurate tempo map, so you'll identify each beat 3 snare in the song, but if you just want approximate measure numbers as a locator feature, then you only need a few identified beats every so often.
Yes, it's sort of tedious, but tab to transient can make it go a good bit faster. Once you're done, you have a really accurate tempo map that can help out quite a bit, especially if you need to time edit.
Best of luck,
-monte-
Old 05-05-2005, 09:40 AM
http://www.digidesign.com/disk/diskflix/
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Determining what QT to use Blazetracks Post - Surround - Video 2 10-13-2012 06:43 AM
Determining tempo of song in 7.4 a.q.s Pro Tools M-Powered (Win) 3 07-12-2008 02:09 PM
Determining The BPM of a Hip Hop/R&B Track Rhapsody 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-19-2007 09:58 AM
Determining ProTools cs Version?? Sharritan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-24-2005 07:31 AM
Determining Loop BPM ??? Lennylaughter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-20-2003 01:39 AM
