Pro Tools 9 HD Software with Venue FWx Option Card
If I understand this correctly, Pro Tools 9 HD Software will recognize a Digi 003 rack. Will Pro Tools 9 HD software recognize the FWx option card on a venue system? Or do I need a Pro Tools 9 license as well?
Re: Pro Tools 9 HD Software with Venue FWx Option Card
My understanding is that PT 9 HD will recognize all the above. You also have the advantage of being able to install the software on another machine and by putting your Ilok dongle into this machine work on that instead.
A friend of mine has found one limitation, he has HD1 core card installed and found that for some reason Pro Tools limits his voices available to those of the HD1 card, whereas, I believe, if he was using a machine without the HD 1 card installed in native mode he has more available, though without the latency compensation. |
PT9 is compatible with FWx. A PT9 iLok authorization (license) is needed in all cases to run PT9. Sheldon |
Sheldon, Thank you for taking time to respond... I do understand that PT9 is compatible with FWx Card. My real question is, can I use PT HD9 software with a FWx card? I currently operate a HD system on a MacBook Pro when on the road. When I do travel, I don't always get a Venue system with HD Cards, but most Venue Systems have FWx cards. Can I use my Pro Tools HD9 Software with the FWx card or do I need a PT9 in addiction to PT HD9?
Ah...got it. Check your iLok account - the HD9 auth is usually bundled with a PT 9 auth, if I recall correctly.
Sheldon |
FS: Avid Venue HDX option card | FOH1 | Buy & Sell | 2 | 03-09-2014 09:33 AM |
Venue + mix rack + hdx card + pro tools hd native card ? | hart07 | VENUE Live Sound Systems | 2 | 05-23-2012 12:02 PM |
Pro Tools LE 7.4cs10 Update for VENUE FWx Option | Avid | VENUE Live Sound Systems | 0 | 07-30-2009 11:59 AM |
Pro Tools LE 8.0cs3 Updates for VENUE FWx Option | Avid | VENUE Live Sound Systems | 0 | 06-08-2009 03:48 PM |
VENUE D-Show 2.8 Standalone Software for VENUE SC48 | Avid | VENUE Live Sound Systems | 0 | 05-13-2009 12:30 AM |
