Old 05-15-2010, 10:40 PM
miek07 miek07 is offline
Default 002 vs 003
I'm thinking about purchasing a used 002 Desktop Unit with motorized fader, since the girl selling it upgraded 003 on her new G5.
003 Prace Tag ranges from $1200 - $2400+
002 Price Tag (used) ranges from $600-$1200+
Would I have any issues using 002 on a 7.4 > Upgrade > PT8 system? (As i'm sure 003 is naively compatible to PT8)
Can I use both 002 AND MBOX at the same time?
besides the cosmetics and price tag, whats the difference between the 002 and 003 ?
Is 003 really worth the $600+ price difference?
(note I hardly ever record more than 4 tracks at the same time as it is, and got 48x8bus analog consoles bussed into my M BOX and Secondary Interface, for recording, though I find 002 faders, mute control, and transport appealing, as my current transport/controller is QWERTY, Mouse and MIDI keyboards)
Thanks!
like 002 Rack vs 003 Rack, 002 Desktop vs 003 Desktop, etc)
Old 05-16-2010, 01:39 AM
sunburst79 sunburst79 is offline
Default Re: 002 vs 003
The 2 unit are very close in sound and features and both are fully supported in 8.0. From what I understand the main reason behind switching from the 002 to the 003 was that the 002 was not ROHS complient.
I own both and I think the 003 sounds a little cleaner and more transparent then the 002 but its not a dramatic difference.
Plenty of used 003's out there also.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 05-16-2010, 02:28 AM
netnoggin netnoggin is offline
Here's what Black Lion Audio had to say about the difference between the 002 and 003 back in January 2008:
We frequently get asked if the 003 is better than the 002, and while it does offer some improvements, we feel it's also inferior in certain respects. According to an email we received from Digidesign's engineering department, Digi has utilized the HD system's internal clock in the 003, and improved the power supply as well. The 003 also appears to be compliant with the European Union's new lead-free directives for electronic equipment, whereas the 002 is not. Conversion is handled by Cirrus Logic, which is a change from the AKM-based conversion found in the 002. The A/D uses the CS5361, a 115dB D/R A/D which is pin-compatible with Cirrus Logic's flagship CS5381 A/D. We consider this an improvement over the 002 because it offers higher dynamic range than the 002's A/D. The D/A is handled by the CS4392, which we felt was inferior to the 002's D/A. The 003's analog stage headroom is increased over the 002 by 15dB due largely to higher analog stage power supply voltage. For the 003's analog section, Digi uses Texas Instruments NE5532, which is a change from the analog stages found in the 002.
NN, aka Hobonoggin
H.I.T. Program graduate (Hobo Internship Training)
Old 05-16-2010, 06:57 AM
Jay_uk Jay_uk is offline
Love it when typos work.
Old 05-16-2010, 08:44 AM
"003 has a better power supply and about +15Dbu more Headroom than the 002" would have sufficed.
Old 05-16-2010, 10:00 AM
More info, same low, low price!
NN, aka Hobonoggin
Old 05-16-2010, 10:01 AM
sw rec sw rec is offline
Incidentally, either of them will work with 7.xx and 8.xx versions of Pro Tools. the 003's were introduced BEFORE Pt8.
Old 05-16-2010, 10:25 AM
One of the single biggest reasons to grab a 003 over the 002 is the fact that it has wordclock which can greatly simplify things when its time to expand your system.
Scott
Core 2 Specs Page
Old 05-16-2010, 11:15 AM
DJ Hellfire DJ Hellfire is offline
The main reasons I got the 003 over the 002 was that it has two headphone outs, which is important since I don't have a vocal booth. Secondly, the 003 has balanced 1/4" connections for the Aux input, while the 002 uses unbalanced RCA connections, which does do well for what I use the Aux for.
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
