please help. pro tools doesn\'t open. crashes at start up
hey
I'm really hoping someone can save me from re-formating my entire computer and reinstalling all of my programs. when i open pro tools in bounces on the dock and then crashes. I've tried everything i know and its still doing it. I've trashed the preferences, trashed the databases etc... i've also completely uninstalled and reinstalled pro tools twice with no luck. I've repaired my disk permissions as well. can anyone suggest anything to try? I have pro tools 7.4 running on OS X 10.4.9 thanks a lot. cheers |
Re: please help. pro tools doesn\'t open. crashes at start up
Have you tried running the prebinding script? This is very common after installing PTs or major system updates.
Read about it and download it here: http://www.digidesign.com/index.cfm?...4&itemid=22904 J |
hey
i downloaded the script, ran it and it said 'Prebinding seems to be OK on this system. Prebinding repair was not performed.' so that doesn't seem to be the problem. i was hoping that was it too. could it be something in my system files? i'm just hoping there's something i can do to fix this problem instead of reformatting my whole comp and reinstalling everything. any other suggestions? thanks |
nobody?
Open up the system log and try to start PT, see what (if any) messages are displayed.
Here's how to access the system logs (not being a smart A, just not everyone knows how to) http://www.osxfaq.com/DailyTips/09-2004/09-24.ws
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
Try removing all the plug-ins from your plug-ins folder, trash preferences, restart and launch again.
If it launches - it's a corrupted or incompatible plug-in causing the problem. If it doesn't launch, try creating a new administrator account, restart and log in to the new account, then try launching Pro Tools again. If it works, then you have a corrupted OS preference in your original account - unfortunately, trying to determine which one it is could be a monumental task and you are best advised to migrate everything over to the new account. |
same issue i checked the crash logs and i got this:
Host Name: matt-guerins-powerbook-g4-15 Date/Time: 2008-03-27 00:13:37.350 -0400 OS Version: 10.4.11 (Build 8S165) Report Version: 4 Command: Pro Tools LE Path: /Applications/Digidesign/Pro Tools/Pro Tools LE.app/Contents/MacOS/Pro Tools LE Parent: WindowServer [89] Version: 7.1 (7.1f60) PID: 384 Thread: Unknown Link (dyld) error: Library not loaded: @executable_path/../Frameworks/CFnd.framework/Versions/A/CFnd Referenced from: /Library/Frameworks/DAE.framework/Versions/A/DAE Reason: Incompatible library version: DAE requires version 7.2.0 or later, but CFnd provides version 1.0.0 |
Please Help!
Were you able to resolve this issue? I am having a similar problem and can't get it to work. |
If the digi advice doesn't work, you might try checking your ilock driver to see if it is up to date.
Pro Tools Crashes on Start up. | mzkguy | Pro Tools 11 | 3 | 08-04-2013 08:32 PM |
Pro Tools 9.0.6 crashes on start up | jeffwenberg | macOS | 10 | 06-17-2013 04:11 PM |
Pro Tools Crashes when I start-up | paulsottilejr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-20-2009 09:53 AM |
Pro tools LE 6.7 crashes xp on start up | seeclouds | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-21-2005 09:06 PM |
Pro tools LE 6.7 crashes xp on start up | seeclouds | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-19-2005 03:17 PM |
