2 22\" LCD screens - Possible ?
Is it possible to use two 22" apple LCD screens on a G4 and still be able to run protools ? The jeronomo card (I believe) doesn't support these 22" screens too well, and if it does, it's only through analog (I might be completely wrong though!).
Anybody any insight / input ? |
Re: 2 22\" LCD screens - Possible ?
This has been discussed in the DUC quite a few times in recent months. Search under "Cinema Display" and you'll find posts which discuss this. The upshot, at present, is that there is no way to do what you propose using off-the-shelf hardware and cabling. The Jeronimo is a VGA output; while you need not only a digital output, but a video card which supports the proprietary ADC, the Apple Disply Connector. Your search will disclose workarounds that some have proposed.
May I suggest you follow this issue into the next several months, as there is reason to believe that products will be available to permit what you, and many others, hope to do. John Caldwell
Pro Tools 2018.4 HDX, 192 and Lucid I/O 5,1 MacPro 12 Core; OSX 10.12.6 |
Possible-YES
After days of trying to solve a similar problem myself I have found the answer. Gefen are relasing on the 1st of march a DVI to ADC converter which will allow you to connect an apple monitor featuring ADC to your computer. The problem is you cant use the DIGI recomended Appian card. But all you really need is a second computer graphics card that featured DVI on it... I know for a fact alot of people are using a non digi specified graphics card... I hope this helps trevor If you have any further questions feel free to email me: [email protected] http://www.Gefen.com/products/extendit/new_kvm_usb_extenders_switches/dvi_to_adc/in dex.html [This message has been edited by trevorM (edited February 04, 2001).]
[b]TrevorM[b] [email][email protected][email] url=http://i.am/trevorM]i.am/trevorM[/url] |
They've indefinitely delayed the release of that product because they are redesigning it. That's the word I got straight from the source. I'm really bummed about it...
Worse than the connection problem is the dreaded 6204- pci bus overload/busy/unreliable. I have a pair of SGI flatpanels (also 1280x1024) and protools doesn't like them. It doesn't even like one of them when track counts get high and the dsp is torqued. This is with a G4450dp. My old beige desktop g3 was fine. Is there any word yet on what the new 4-slot boxes are doing?
I got word from Gefen (thanks to TrevorM) that they have a solution (ADC to DVI convertors/extenders), but they're over $2500 each. I hope somebody else is going to make these convertors soon. Darn apple again with their proprietary connectors.
[This message has been edited by Charles Deenen (edited February 05, 2001).] |
thanks Bryan. Yes, I was aware of these 2, but I need to extend around 40 feet. 18 feet won't reach the machine-room. It seems that I still have 1 more problem: no dual-monitor DVI or ADC cards available yet.
-cd |
Charles,
Actually, Gefen has or will have two methods of extending ADC (from what I understand): 1. The military-standard fiber optic version is indeed $2700 bucks and will shoot the signal 300 feet. 2. Realworld version that converts ADC to DVI, extends and DVI cable (only a max of 18 feet) to a DVI to ADC convertor (which provides power) into your adc monitor. Don't know how the integral USB is handled...I've asked, waiting for a reply. |
Check out www.inlineinc.com. 30-75 feet DVI extenders that are much cheaper than Gefen's $2500 DVI extender. -charles |
I have the new Gefen box, but it will only go about 12 feet. The longer DVI cable I purchased (to give me a total of 18 feet) results in some serious but 'workable' digital noise. I'm going to buy one of those Inline cables and see if it does any better.
B |
Is it possible to run 3 screens on a g5? | Premo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-26-2008 03:24 PM |
No Help Screens in 7.3.1 | 510man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-01-2007 09:55 AM |
No Help Screens in 7.3.1 | 510man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-24-2007 11:29 PM |
using 2 screens in PT - how do you do it? | propofol | Tips & Tricks | 6 | 02-16-2007 09:33 PM |
three screens | stonedef | Post - Surround - Video | 3 | 07-28-2006 10:09 AM |
