Old 10-18-2009, 02:42 PM
JRup JRup is offline
Default quick question - Mbox Mini question - i forget
I had an M-Box Mini but switched to an 002 a while back. My buddies are in from out of town and want to record their rehearsal so he was asking about using the Mbox Mini to do a stereo record. i forget if i can set up 2 mics ( i have a cable to convert one of them to 1/4" ) but my question is will it actually take the 2 inputs and let me record the 2 different singles on the MINI ? i dont recall if it allowed me to do it way back when i used it
any help refreshing my brain would be greatly appreciated.
thanks
Old 10-18-2009, 02:45 PM
LincolnT LincolnT is offline
Default Re: quick question - Mbox Mini question - i forget
The second channel is a line/di input. No mic pre-amp.
The first channel is mic/line/di.
So, yes, you can do stereo recording as long as the second channel is not a mic. It can be a guitar or line level.
You would need a mic pre-amp to do stereo mics. You could use the mic pre-amps on a mixer.
MBox 2 Pro connected to motherboard 4 pin firewire port
Dell Inspiron 9300 laptop
2.0 gHz Pentium M
2 gB ram
Lacie Rugged 5400 rpm firewire 800 on Siig Cardbus adapter
Roland 700SX stage piano
Studio Projects C3 mics
Melodyne Plugin
Dual Boot:
PTLE 8.0.1 on Windows 7 Enterprise 32 bit
PTLE 8.0.1 on XP Media Center SP3
Old 10-18-2009, 02:48 PM
if i pulled 2 outputs from the rehearsal mixer? i should be able to run the line inputs into it then. i could definitely try that.
thanks
Old 10-18-2009, 02:52 PM
thanks
That should work.
2.0 gHz Pentium M
2 gB ram
Melodyne Plugin
Dual Boot:
Old 10-18-2009, 02:55 PM
thanks so much
quick question on mac mini gprok macOS 5 04-22-2013 01:05 PM
M Box 2 Mini. Quick question. harry3232010 macOS 1 09-27-2011 08:02 AM
Downgrading MBOX 2 to MBOX mini (Quick question) Mista808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-09-2011 08:29 PM
Quick Question- remaping with Mbox2 Mini jmitchell1532 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-07-2009 11:36 AM
Quick Question - MBOX MINI ld_neil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-12-2007 04:50 PM
