Old 09-05-2002, 02:04 PM
keithma keithma is offline
Default PT LE crashes when I try to import audio/midi
Every time I click on either one of these options, Pro Tools quits on me. Has anyone else had this problem? Is it some sort of extension conflict? Any insight would be much appreciated.
Old 09-07-2002, 02:48 AM
Dragonfyre Dragonfyre is offline
Default Re: PT LE crashes when I try to import audio/midi
I have this problem sporatically with the 32 track Le.
Old 09-07-2002, 05:56 AM
spudsound spudsound is offline
I have Had this problem Also when working in a new session. I emailed Digidesign about it over a week ago but have had no response.
spud
Old 09-07-2002, 07:50 AM
EricHSound EricHSound is offline
I have also had crashes but they are unpredictable. Working all day with no problems and then PT vanishes but DAE stays open and the OS (9.2.2) kicks out a dialogue saying PT app crashed and to save in different location and restart. I can then shut other apps down except DAE and if I try to restart everything locks up. This will happen without all the other apps running (Korg Oasys, Samplecell, Reason). Crashes happen when I:
import audio, close a session, quit a session.
Presently I have rebuilt my system, drive reformat, clean install of OS and basic audio setup only. I have not had the same problems but given the fact that the crashing was not predictable only time will tell.
Old 09-09-2002, 01:04 PM
DigiTechSupt's Avatar
What utility did you use to format your drive(s)?
-For all IDE/ATA drives, use Apple Drive Setup
-For all SCSI drives, use ATTO EPT 2.3.2 or 2.8.1 (only use v2.8.1 if running Mac OS 9.2 or later)
-For all FireWire drives, use the Special>Erase Disk command in the Finder.
Additional suggestions:
-Trash the DigiSetup File, Pro Tools preference, and DAE prefs (the entire folder) from the System Folder>Preferences folder. Empty the Trash and restart the Mac.
-Rebuild the Desktop file for all drives in the system. Hold down the Apple+Option keys while the extensions march across the bottom of the screen during boot-up. Hold the keys down until you get a window prompting you and then Click “OK”.
-Increase the Preferred memory size of the Pro Tools and DAE applications. Increase the DAE Preferred size to 90000k (90MB) and Pro Tools to 80000k (80MB). Never change the Minimum memory size. If you have, you can set it back to the default setting by typing a 0 into the field and press Enter on the numerical keypad.
Brent
Avid Audio Tech Support
Support FAQ
Old 09-12-2002, 07:58 AM
Thanks for the reply Brent. I have followed your suggestions. So far so good.
peace
Pro Tools 10.1 crashes-import audio from CD cplaza Windows 5 04-02-2012 02:32 PM
Audio Import auditioning audio crashes PT LE 8.0.3cs2 TMT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-15-2010 12:48 PM
PT 8.1 crashes when attempting to import audio Andling Pro Tools M-Powered (Win) 1 09-05-2009 07:38 PM
verison 6.1 crashes when I import audio Soberphobia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-08-2003 06:33 PM
Import audio crashes?? tandem Tips & Tricks 1 02-14-2003 05:16 AM
