Old 12-19-2016, 10:20 AM
Fezzler Fezzler is offline
Default Which output to use now?
Love my 11R. I have it connected to one computer via USB to use with Pro Tools. I have the Main Output (L&R) connected to studio monitors for quick practice or enjoyment.
Now, I have a second computer I use Cubase on. My interface is a FocusRite Saffire Pro 40. While it has SPDIF, it is currently used by another piece of gear. But I have several analog inputs still available.
For quick tracking of 11R with this second computer without disconnecting my current connections, can/should I use Output to Amp to the FocusRite? The FX Send (Left or L&R)? Use the Phones out?
I read the manual. I just wasn't sure if Output to Amp would send too much signal to the FocusRite input.
Also, on another thought too, can I got out the FocusRite, in the 11R FX input and back to a FocusRite to access the 11R as an effects rack too? Anyone doing that?
[SIZE="2"][COLOR="Blue"]Intel Haswell-E Processors 3.3GHz Core i7-5820K 6-Core; Memory - DDR4: 16GB DDR4-2400 Quad Channel (4 x 4GB); Primary Drive (OS): 240GB SSD SATA3; Secondary Drive (Audio): 2TB 7200 rpm SATA2; Graphic Card: 1GB (HD5450) Dual Display Graphics Card; Optical Drive: 22x CD/DVD Dual Layer Burner; Windows 10 64-bit; PT 12.5; Studio One Pro 3.2; Cubase Pro 8.5; REAPER; MixBus 3
Old 12-20-2016, 09:50 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Which output to use now?
That will work fine, just make sure you have the output set properly so you get the rig sound on the output.
I think you would have to use the line inputs for this. You'll also have to make sure you have the line input selected in the input menu when doing this.
Will
System Details
No output device selected in Studio Monitor Express, using Default Output (Mbox Pro). Focuret 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-12-2014 07:33 AM
Whats the Difference between Bounce to Disk Source -> Physical Output vs -> Output Epik Productions Pro Tools TDM Systems (Mac) 8 05-03-2013 12:48 PM
No headphone jack output - Meters showing output Hotcrazyfruit Eleven Rack 6 05-06-2012 12:09 PM
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs MR290378 Eleven Rack 12 11-29-2011 05:10 PM
Help! I can't get my main output to work, and I can't make a stereo output! oceanlove_1 Pro Tools 9 1 06-27-2011 05:23 AM
