Old 02-17-2011, 03:10 AM
Pasz Pasz is offline
Default Swapping my 002r + Focusrite Octopre mk1 with ... what?
Now that it kinda doesn't matter what interface you're using, I'm looking at replacing my 002 rack and Focusrite Octopre (mk 1) with ADAT card. They sound pretty good but I know there's newer, better sounding alternatives out there.
My budget is 1500 Euro (or around 2000 USD), max.
I'd still like to have 10 - 12 mic pres in total, so I though maybe this was a good combo:
- RME Fireface 400 (2 mic pres)
- OctoPre MkII (8 pres, no compressors, don't need them)
RME's convertors are very high quality, and presumably a lot better than what my Digi002r has on board. The question is: how is the mic pre itself?
Another question: How are the pres and convertors on the OctoPre?
The major question is: Will the setup I described be a step up for me, recording/playing back quality wise?
Maybe you have a better suggestion? Remember, my budget is a maximum of 1500 Euro's or 2000 USD.
I'm using a 24" iMac C2D + 4gb ram + Snow Leopard + Pro Tools 9 + Digi002R + Euphonix MC Control v1.
Old 02-17-2011, 06:36 AM
Default Re: Swapping my 002r + Focusrite Octopre mk1 with ... what?
I'd be tempted to go with a pair of M-Audio ProFire2626 units. Or a used 003R and either a 2626 or a Presonus D8 in the lightpipe. My reasoning is that Avid hardware still seems to hold an edge in functionality, specifically dealing with latency and buffer for recording.
Old 02-17-2011, 08:12 AM
tribedescribe tribedescribe is offline
I own currently m-audio profire 2626, and apogee ensemble. I also have owned the Rme adi-2, m-audio 1814, and a Black lion audio modded m-audio projectmix. The Rme 400 is excellent and on par with the apogee ensemble. Although the ensemble gives you 4 pre's compared to 2 on the rme 400. The profire 2626 sounds great, but is a definite step down from the Rme and apogee. Give the Ensemble a serious look the pre's are excellent, you might find one used for $1500 and get the focusrite for $500, that's what I would do.
Out of products I have heard and used I would rate them as follow's(I am sure others will disagree.)
Metric Halo uln-8
prism orpheus
Black lion audio Sig. mod
Rme UFx
Apogee ensemble
Rme 400
Black lion audio tweak head mod
Rme 800
Stienberg mr800
M-audio 2626
Digidesign 003
Digidesign 002
M-audio project mix
M-audio 1814
Old 02-17-2011, 08:16 AM
NewdestinyX NewdestinyX is offline
Default
An OctoPre is ONLY a pre. No converters to digital. Not an interface.
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard
Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS
Old 02-17-2011, 03:57 PM
The Dougfather The Dougfather is offline
Pasz,
I had up until a few months back the Octopre Le, and i'm not sure if there is mass of difference between the two units but i found those platinum pre's terrible. Very thin and leaning very much towards the high end.
I still have the 002R with a presonus digimax FS and it's a much better unit. Better sounding, better clocking, better build quality. I have no experience with the M-Audio kit but at this price point i would recommend presonus, as do many others. I might even go as far to say that if all you need is better pre's then why not keep the 002R, shell for a really lush twin preamp which you can use via SPDIF and get a better 8 channel. You could even use the ADAT or SPDIF units to give you a better DAC stage over the stock 002R, provided they have analogue outputs.
Just my two cents.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
C24 & Focusrite OctoPre Mk II Zhiksy ICON & C|24 1 05-29-2013 02:38 PM
003R+ rack with octopre VS Focusrite Octopre x2 through M-audio Lightbridge Sweepxcore General Discussion 12 05-24-2009 06:44 PM
002R, Focusrite Octopre LE & BehringerBCF2000 evoltuions_end 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-13-2006 03:34 PM
Swapping Mbox and 002R problems musiqtech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-18-2005 10:13 AM
the new Focusrite OctoPre Bob Mould Tips & Tricks 1 01-24-2002 05:59 AM
