Old 02-05-2011, 05:07 AM
SixChurchStreet SixChurchStreet is offline
Default Daisy chaining on IMac. Any problems?
Does any do FireWire daisy chaining on an iMac (specifically the 27")?
I currently do it on my 13" MacBook Pro. MacBook to G-Drive Mini to ProFire 610 and it works flawlessly.
I'm going to replace my laptop with an iMac. Can I expect the same smooth sailing with daisy chaining on the iMac?
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4
Old 02-05-2011, 06:56 AM
mikebeck mikebeck is offline
Default Re: Daisy chaining on IMac. Any problems?
I have a FW800 drive attached to my new iMac, with an Apogee Duet chained to the drive. No problems so far. Been using it this way for about a month.
Old 02-05-2011, 07:08 AM
Default
Good to hear. Thanks!
Old 02-05-2011, 07:36 AM
nst7 nst7 is offline
I have a 2007 Imac. I have successfully chained 2 audio hard drives, a 3rd drive streaming BFD2 samples, and a 003R, all from the 800 port, with lots of tracks and plugins.
Be aware, though, that the G-Drives have had certain finicky issues in regard to daisy chaining. If for some reason you have any problems, that's the first place I'd look.
Old 02-05-2011, 09:10 AM
Default
Thanks for the heads up. Though it's been perfect with my MacBook Pro for the last 10 months.
Old 02-05-2011, 01:06 PM
Pasz Pasz is offline
I have this:
iMac (2008 I think) -> 002r -> OWC bus powered HD
No problems
I'm using a 24" iMac C2D + 4gb ram + Snow Leopard + Pro Tools 9 + Digi002R + Euphonix MC Control v1.
Old 02-05-2011, 01:51 PM
Dism Dism is offline
Default
Originally Posted by Pasz View Post
I have this:
No problems
I think Avid should adopt this recommendation if you are using a bus powered drive. This configuration is the only way I've ever been able to use for bus powered stability.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
daisy-chaining FW HD 77pro macOS 12 03-22-2011 12:36 PM
Daisy Chaining? SkiFiend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 09-30-2008 07:22 PM
FW daisy chaining clausiii 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-18-2008 09:57 AM
FW daisy chaining clausiii Pro Tools M-Powered (Mac) 1 03-18-2008 08:50 AM
Daisy chaining I/Os RexTrax Pro Tools TDM Systems (Mac) 2 08-06-2007 04:08 PM
