Old 01-05-2022, 10:40 AM
Swayze Swayze is offline
Default Create project from template, no sound
I'm using a Motu M4. I press play, no sound. I resetted all the IO inputs and set the playback engine, the meters aren't even moving. It's all very unintuitive.
I figured I'd open a sample project to see how everything works, but that's kind of hard when it doesn't work.
Any ideas?
Old 01-05-2022, 12:28 PM
Default Re: Create project from template, no sound
Tough to say without seeing what you are doing. Instead of starting with a template, start a new session(and I do mean "session" and not "project"). Create a mono audio track and a stereo instrument track. For the mono audio trrack, set the input to the first input of your interface and click the red "record" button on the track and see if you hear your mic(or whatever is plugged into that input) and if you see the meter move(assuming you have the preamp GAIN turned up to the proper level). If that's working, great. On the instrument track, insert one of the included instrument plugins(MiniGrand is my usual recommendation for testing). Once the plugin is fully loaded, mouse-click on some of the keys on the plugin. Are you hearing piano? Report back after trying these things.
Old 01-05-2022, 01:31 PM
^^^ Good advice But before doing that make sure Pro Tools can play back basic content. Create a new empty session (not from Template). And drag and drop a known good commercial audio recording into the edit window and you should see Pro Tools ask you about creating an audio track. Get that work work and play correctly before trying to do anything else.
You need to learn how to use Pro Tools, randomly trying stuff is not the best way, and very frustrating for you. There are no end of useful tutorials on getting started using Pro Tools on places like YouTube or different paid lesson services like Groove3. Pro Tools is like say AutoCAD, you don't just open it up and design a building, or even a garden shed, or shovel. It's too complex to spend your time trying to work out yourself how it works, you should to be following tutorials and documentation (Pro Tools Reference Guide... have the PDF on your desktop readly to search in for stuff... it's a very good reference guide *not* at all a getting started tutorial).
Create New Project - There was an error posting the project. descendant Pro Tools | Intro Discussion 13 04-24-2016 06:35 PM
How To Create a Template in PT6.9 Mac OS X schpilkas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-03-2006 04:53 PM
How to create a template out of this? Petander Tips & Tricks 6 04-21-2006 08:36 AM
How can I create a Project template Peter Groom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-10-2006 12:44 AM
can't create a template in 6.9 andre tchmil Pro Tools TDM Systems (Mac) 2 09-16-2005 06:00 AM
