Old 11-06-2010, 06:05 AM
trock trock is offline
Default anyone have eucon working with artist series?
i downloaded and upgraded to PT 9 no issues
downloaded and upgraded eucon to 2.5.6. no issues
rebooted and recycled power etc on all units
in PT/periphereals i checked under ETHERNET CONTROLLERS the Eucon on and applied etc
the COntrollers do nothing when i start PT. nothing
and when i tried logic they did nothing, this worries me.
i will try it again soon but right now thats where i am at so i just wondered if anyone else is rockin?
thanks
PT 10 - Mac Pro Octo 2.8 - 10.8.3
Artist series - MC control v2 - 2x mc mix - mc trans
Apogee Symphony
Old 11-06-2010, 06:35 AM
Tim R. Tim R. is offline
Default Re: anyone have eucon working with artist series?
We had it working (sort of). It seemed a little flaky though. Look in the Eucontrol setup (click the green circle in the menu bar). Make sure your PT's system is showing up in the "Workstations" tab.
Old 11-06-2010, 06:41 AM
will do
thanks Tim, i forgot to check that.
Apogee Symphony
Old 11-06-2010, 06:43 AM
Technog0d Technog0d is offline
If you used HUI mode before EUCON was supported then you have to take HUI control emulation out in System Preferences before it will work with EUCON. I found that is what fixed it for me.
Regards,
Michael Chenetz
http://noisemakers.info/
http://max4live.info/
yep it is there.
not sure what to do now
i reinstalled 2.5.6 again and all 4 just sit here dead and don't map to Logic or PT at all
Apogee Symphony
Old 11-06-2010, 09:19 AM
just to keep anyone interested updated the logic part works fine now, PT still not mapping for some reason
Apogee Symphony
Old 11-06-2010, 09:25 AM
wizprodux wizprodux is offline
Don't forget to run the Firmware Update on EuControl for each of your controllers.
Remove HUI from the Euphonix App
Select EuCon from PT Peripherals
Old 11-06-2010, 09:31 AM
macakinho macakinho is offline
Mine is working flawlessly!
Downloaded the update, installed it, upgraded the firmware, checked the workstation tab in EuControl and removed Pro Tools from the HUI control emulation in System Preferences!
So far, no problems at all! All the new features seem to be working!
Old 11-06-2010, 10:01 AM
Oliver M Oliver M is offline
Yes, updating the firmware of all units should fix this.
Oliver
Old 11-06-2010, 12:33 PM
all fixed and PERFECT. I had PT set as HUI still!
thanks all!!
MAN this is SWEET!
Apogee Symphony
[IMG] code is Off
Avid Artist Mix Series Eucon 8 Fader Studio Audio DAW question shamanrock Pro Tools 11 3 03-07-2014 11:56 AM
Artist Control not working with Eucon 3 on OS X 10.8.4 Jerry Woolsey Artist Series 1 06-24-2013 01:21 AM
My Artist Series Registration Not Working Xill Artist Series 6 07-09-2011 09:01 AM
Lets Put All Our Artist Series Eucon PT9 Woes/Bugs In One Place engininja Artist Series 23 06-27-2011 05:28 AM
CSCooper MCS Series vs EU Artist Series? GrievousAngel Artist Series 1 12-01-2010 01:10 PM
