Old 08-24-2004, 05:08 PM
IPerez27 IPerez27 is offline
Default Sampling rate problem
I just started into Post Production at an independent film facility. I've been recently having problems with my sampling rate.
I open new sessions in 48k, work on them but without warning the session sounds slow and lo and behold the session is now running on 44.1k. Okay, so I'll open a new session in 48k and import the session data, all good until a few moments later and boom back to 44.1k.
It's getting a bit irritating. It does this whether we are editting, importing audio or recording ADR or foley. I've set the Digidesign core Audio to 48k and that doesn't change. I'll open up PT first, make sure the hardware setup is running at 48k before opening up a new session or an old session that was running at 48k.
I've downloaded the patches (cs5, 6, and 7) and still the same problem. We were having display and setting difficulties so we assumed it was a low battery. The battery is replaced, the display prob fixed but PT is still giving me problems. I've worn my eyes red reading through posts and using the search engine for help.
I'm running a 1.25 dual G4 powerpc at OS 10.3.4 with PT LE 6.4 (a la patches) on a MBox (002R is in the mail).
Anyone else gone through this? Got an ADR session in the morn would be nice to have this fixed.
Sound Editor
Old 08-24-2004, 05:45 PM
Default Re: Sampling rate problem
What's the clock set to in your Session Setup Window?
Make sure it's in INTERNAL.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 08-24-2004, 06:25 PM
It's always at internal.
Sound Editor
Old 08-24-2004, 08:14 PM
scott waz scott waz is offline
Any other digital equipment that might be fighting you for sample rate control? Then disconnect.
Tell us more about you setup.
-sw
Scott Waz CAS
Philadelphia Post
www.phillypost.tv
~a Dream Out Loud company~
Old 08-24-2004, 08:38 PM
I work mostly in the box with no control surface. The only things that are coming in and out of the mbox is a mic XLR cable. Two 1/4 cables out to M Audio speakers and a DA-60mkII connected by SPDIF. However the Dat machine is off if I'm not digitizing audio and this has been a problem when we didn't have the Dat machine in the room at all. But I'll try completely disconnecting the DA-60 to see if this helps.
Any other ideas?
thanks,
Iris
Sound Editor
HTML code is On
Problem with sampling rate!! Kemo3ce macOS 4 02-03-2013 01:40 AM
Anybody know what the max sampling rate of PT 8.0 LE is? Fabb2004 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-09-2012 10:58 PM
Sampling Rate Problem Please Help D.O.T General Discussion 0 07-13-2008 06:33 AM
16k sampling rate? guy.fi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-31-2007 03:03 AM
mbox sampling rate madincraft 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-05-2003 11:16 PM
