Old 05-27-2003, 11:59 AM
Alhuero Alhuero is offline
Default Mbox Analog Input with Digital Output
So I thought I figured out a novel way to use the pre's on the Mbox to feed into an external 8-track recorder with suspect pre's, but I'm getting some strange clicking (jittering) on the inputs after running them for awhile.
What I've done is hooked up two microphones to the analog inputs on the mbox and setup a phantom session enabling record on two tracks panned hard left and hard right. I've then taken the S/PDIF RCA digital out of the mbox to a converter which translates the RCA to an Toslink optical output; the required feed to my recorder.
It all seems to work fine for awhile, but eventually I start getting a clicking noise on the mbox inputs that continues even with the mics disconnected. The only way to get rid of it is to close the session and reopen it.
I'd be interested in any guesses on what might be causing this.
Thanks, Alex
Digidesign 192 Analog I/O with Avid Input, Output and AES DB25 Breakouts N1h1l1ty Buy & Sell 5 09-04-2014 10:02 PM
Digidesign 192 Analog Input Card and Analog output Card for Sale MusicEngineer Buy & Sell 1 03-03-2014 09:03 AM
Does the Mbox output to both analog and digital simultaneously? DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-06-2008 09:09 AM
DIGI 003 Factory - No Analog Audio Input / Output travisgregorash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-08-2007 08:53 PM
Digital Output from 888/16 isn't compatible with Digital Input of TC M2000 & PCM 80 beerbr Pro Tools TDM Systems (Mac) 0 11-02-2000 08:01 PM
