Old 01-12-2012, 09:24 AM
papitopinillo papitopinillo is offline
Default Impossible to record audio because Audio Input is not active?
i'm had been getting this message when i'm opened pt.9
Impossible to record audio because Audio Input is not active. Open the ASIO DirectX Sound Full Duplex Setup Dialog. Make sure that a device is selected in the Input Ports section and that it's check box is activated.
protools start no problem then i go to options to change the interface to my m-box or fast track pro the computer crush and i got a blue screen..
any idea thanks a lot people
Old 01-12-2012, 10:22 AM
cwsand's Avatar
cwsand cwsand is online now
Default Re: Impossible to record audio because Audio Input is not active?
Are you also selecting the interface under Playback Options?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 01-12-2012, 01:09 PM
YYR123's Avatar
YYR123 YYR123 is offline
how does your fast track look in the device manager....????
Daniel
Old 01-12-2012, 01:17 PM
YYR123's Avatar
Hey Chris - on another note are you running your saffire40 in conjunction with the 56? - What's your setup like?
I just received my liquid 56 in the mail today...can't wait to install..
Daniel
Old 01-12-2012, 06:30 PM
guys even worse know i don't even get the chance to see protools open start to load and at the end when is about to open blue screen my pc.
i got a windows 7 sp1 ,intel i7,7gb
any idea
please help i did uninstall pt9.0.6 and i install 9.02 i got the same issue .
thank for support !
Old 01-13-2012, 11:32 AM
here is the error code when i get the bsod 0x000000D1
thanks
Old 01-13-2012, 12:01 PM
cwsand's Avatar
I'm not familiar with this - is it a control app that comes with the mbox? Usually you want Pro Tools to handle all the connectivity. Also, you should go ahead and post a SANDRA report.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 01-13-2012, 04:22 PM
I will do the Sandra report I don't know how to do it but I'll find out,this is the main issue I can run protools only without interface ,if Iconect my mbox 2 and go to options -playback -and I swipe to the mbox I get the bsod.
Thanks
Old 01-15-2012, 04:42 PM
cwsand's Avatar
Thanks
Here are the SANDRA instructions:
Use SiSoftware's Sandra Lite application to generate a full system profile:
www.sisoftware.co.uk
Under SiSoftware Sandra, click on "Download & Buy" to download the free Sandra Lite version or purchase other versions. After installing Sandra, click on the 'Hardware' tab and run the 'Computer Overview', then copy and paste into your post here on the DUC.
I have the Pro 40 and Liquid 56 synced via firewire and the OctoPre is connected to the Pro 40 via ADAT for 24 in / 16 Out. I would have just used 2 OctoPre's but I needed more than 8 outputs. This setup works for me although it's not supported by Focusrite. I recently upgraded my Gigabytye motherboard to Rev. 2.0 (the first one was hosed) and have been having a hell of a time getting into Pro Tools without the "ASIO Properties have changed error". When I uninstalled the Marvell software it started working fine. I should have known better than to install that extra Gigabyte crap after my experience with the first motherboard!
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 01-20-2012, 10:54 PM
I fix the blue screen pt is working fine
pro tools not recognising audio input, cannot record audio! mr_J_stylez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-01-2017 07:44 AM
FWx with PT 9, Record / INPUT results in stuttered audio output mu-tron-kid VENUE Live Sound Systems 2 10-02-2012 01:40 PM
Audio won't record through instrument input CoreyMaim Pro Tools SE and Essential (Mac) 3 03-04-2011 10:56 AM
Losing communication with audio interface, impossible to bounce to disk or to track nguetecho 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-10-2009 10:00 AM
Can I record in stereo using the Powerbook G4 mini-jack external audio input? msa007 Digidesign Hardware & Software 2 01-26-2003 08:54 AM
