Old 02-09-2015, 04:11 PM
musicalavtech musicalavtech is offline
Default Cut time?
This is an old issue, but I've forgotten how to delete measures, bars, and any space beyond the end of a song. There is a few minutes worth of just space after the song ended. No midi data, although some minor automation just before the end of the song. Using cut time, with all tracks viewed, did not help much.
OSX10.6.8, 1st gen Power Mac,
PT8.0.5, Mbox2
Old 02-11-2015, 05:30 AM
Default Re: Cut time?
Make a separation at the spot you want to cut and right click on the part you want to cut and select cut from the menu that comes up. Then delete the unused stuff from the regions list (clips list in PT11).
Jack
QAPLA!
BIG BUG: Wrong playlist calculations when using AS Pitch 'n Time or Avid Time Shift Franco1967 Pro Tools 11 1 01-25-2014 11:31 AM
Clip Gain won’t update in real time during playback on Elastic Time tracks yanos macOS 0 06-03-2012 03:48 PM
message reads I/O setup has changed since last time session was opened last time peteor96 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-05-2011 08:29 PM
Slow boot-up time PT 8.0.4cs2 on Win 7 - plug-ins load every time jmac146 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 01-02-2011 04:49 PM
DIGI FEEDBACK: 'Real Time' Bounces-Time Effective? csiking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-20-2005 06:41 PM
