SPDIF
yes, yes...lots of questions.....
I am working with an mbox but would like to track more than two channels. My friend has a metrichalo box that has some 8 mic pres. Can I run the metrichalo through my mbox using SPIF? What kind of cable do I use? Will regular RCA work? Will Protools then recognize all the new inputs? Is there any documentation on the necessary config of hardware and software? |
Re: SPDIF
No, SPDIF only supports 2 channels - no matter if you go analog or digital you cannot record more than 2 channels at once with the Mbox.
ProFire 2626: SPDIF COAX & SPDIF OPTICAL Simultaneous success!!! WHAAAA HAPPENED??? | cueball73 | macOS | 0 | 05-22-2012 12:41 PM |
mono like sound from spdif out (GA-EX58-UD3R) to spdif in (Omni ) | chrisdee | Pro Tools HDX & HD Native Systems (Mac) | 9 | 04-02-2012 05:10 AM |
Spdif RCA to Spdif Optical conversion - degradation?? | Hollow Body | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-17-2011 08:21 AM |
Digi 96io - can you mix Optical SPDIF and phono SPDIF? | buckaroo | Pro Tools TDM Systems (Mac) | 1 | 08-24-2009 11:20 AM |
Echo Mia W/ SPDIF also does RCA style SPDIF cause the same crashes as optical?? | Paul_m | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-16-2003 05:41 AM |
