Old 02-10-2020, 07:08 PM
drasmith drasmith is offline
Default clock discrepancy?
PT has started showing me error messages the there is a discrepancy between my internal and external clock setting. But, there's not! I checked it a dozen times. I even tried setting up a new session and before i could set up and click OK I had the error. I'm using a Digi 003, a Pre Sonus DigimaxLT with PT2019.
Any help is greatly appreciated.
Allen
Old 02-10-2020, 07:24 PM
anothercolour anothercolour is offline
Default Re: clock discrepancy?
It might be time to replace the internal battery in your computer if you are using an older machine.
Old 02-10-2020, 08:34 PM
Thanks. Would have thought the same but I’m working on a brand new 10 core machine.
Old 02-11-2020, 12:24 PM
As always...asked?... and answered. After pulling my hair out and frying my cranial scrambled eggs I thought maybe I should try a different tos-link--- yes sir! Just like new. (And I thought those things never failed).
Thanks for letting me work out my frustrations here.
Allen
Old 02-11-2020, 01:35 PM
JFreak's Avatar
JFreak JFreak is online now
002/003 family drivers are not compatible.
002 is last tested against 10.8 "Mountain Lion" and 003 against 10.12 "Sierra" -- on the other hand, PT2019 needs at least Sierra so unless you are running 10.12.6 you are out of luck.
PT compatibility info here
00x driver info here
Janne
PT 10 TDM vs PT 12 HDX 1 voice discrepancy Loudigi Pro Tools 12 1 06-16-2016 05:56 PM
LTC chase and 9 pin discrepancy nobby Pro Tools TDM Systems (Mac) 6 09-25-2009 05:29 PM
Pan law discrepancy between TDM and LE el Daniel Tips & Tricks 6 05-31-2007 03:41 PM
-3.5 db discrepancy between PT and Final Cut Pro LuckyFeet3 Post - Surround - Video 5 05-21-2007 03:46 AM
headroom discrepancy? szac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 03-07-2005 11:31 AM
