Audo Pull down .1%
really weird. (ptHD 6.2) I have QT files captured locked to ref and tc with burn-in. When I lay them into the session, they are out of sync. If I pull audio down .1%, then spot movies to tc # in burn.....then put pull down back to none...I am in SYNC ( no drift ). (Obviously tc #'s are NOT in sync )
When I look at Original time stamp of audio files, they are different than current placement....but when I pull audio down .1%, the Time stamp matches the current position. Does this tell me the tracks were transfered from da-78 into pt with audio pull down ENGAGED?? OYE! These are music mixes that will be slipped into place if need be. I did an omf export test...with audio pull down on ....with source set to 47,9XX, and dest set to 48k....to bring back to pitch..... pulled it back to code position and code matched. I did not do the transfer, but assume that is where problem existed. any ideas?? R |
Re: Audo Pull down .1%
Is your session set to the right time code type (29ND, 30ND, etc)?
oh yes...it is 29.97df. was transfered at that. I imagine the pt system was locked to word clock from 88's as well.
Call me by my real name, "Postman" |
The sessions are at 29df...which is correct.
Yes, I am spotting movie to tc...not moving the audio. When I spot movie to tc number on timeline, it is out of sync. to get it in sync, I put session in audio pull down .1%, and spot movie to match burn in with timeline location. ( movie is still out of sync) then I put audio pull down BACK to NONE. Now the numbers are off, but movie is in sync with no drift. sounds like maybe, like you have said, the 88's were set to NDF...and they put pt in jam.(ouch!) you are correct, pitch would not change in the omf export....but timing(placement and length ) thanks Rob |
If you are using HD you can pull the video up or down independently of the audio, could it be the video maybe needs pulling UP? I don't understand why you would put something in pulldown to spot it, then change it back. That makes no sense.
this method I arrived at that worked...that's all.... makes no sense,I agree.
The strange thing again, If I put the sessions in audio pull-down(.1%), then check the current location of a region, it is INDEED at it's Original Timestamp. If NO audio pull is enabled, the current location of regions does NOT match original timestamp. R |
I believe I know how this happened now!
I think the 'Auto Pull Match Framerate' parameter was selected in the frame rate pop-up menu. when the person doing the transfer changed the frame rate, a pull down was inadvertantly turned 'ON'! OYE! Watch out for this one r |
Finding missing audo message | WRX07 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-06-2005 01:05 PM |
Pull Up/Pull Down and digital transfers | dmfisher1 | Post - Surround - Video | 8 | 10-28-2004 11:45 PM |
Mbox, Core Audo Driver HW Buffer | Surf Twang | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-11-2003 12:35 AM |
Time code pull up pull down? | Digipics | Tips & Tricks | 1 | 08-07-2003 09:23 PM |
Pull-ups / Pull down question | georgia | Tips & Tricks | 4 | 06-01-2001 05:21 PM |
