Old 09-12-2014, 02:16 PM
AlexLakis AlexLakis is offline
Default Re: Pitch Shift II does not work properly!
Originally Posted by tanjerinepost2 View Post
Can we have the old one back please avid .
Make that another vote for the old one back (I've had the same experiences as others in this thread.)
And the old elastic audio/x-form from 7.4 while we're at it.
Seems we've been moving backwards in the pitch/time-stretch department...
Old 09-13-2014, 12:17 AM
groundcontrol's Avatar
groundcontrol groundcontrol is offline
We have more pretty lights to look at...
Can you please send yourself over fiber to go spam some other forum?
Darryl Ramm
Old 09-13-2014, 02:04 PM
Chief Technician Chief Technician is offline
Arrow Re: Pitch Shift II does not work properly!
Pitch II uses an entirely different algorithm than Pitch. Avid is well aware of this issue.
Jonathan S. Abrams, CEA, CEV, CBNT
Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10)
Old 09-15-2014, 01:00 PM
DigiTechSupt's Avatar
Post Re: Pitch Shift II does not work properly!
FYI, Pitch II is a different algorithm, but while it won't respond the same way as Pitch it should not be a major step backwards.
If you have additional info about your system or the content you are working on that could help us.
Also, adding it to IdeaScale would be good. edit: Added here.
Thank you,
JC
Avid Audio Tech Support
Support FAQ
Last edited by DigiTechSupt; 12-03-2014 at 07:00 PM. Reason: Added the IS link. -JC
Old 12-01-2014, 08:06 AM
Runnytofu Runnytofu is offline
Same use case as OP, and experiencing the same problem. Is there any fix for this, or failing that, is there another program that will pitch the human voice appropriately without severe artifacting? I used Melodyne last week because I only had to pitch a few lines, but pitch shift II is pretty much useless for me now, and Melodyne takes significantly longer to process than I'd like.
Old 12-01-2014, 09:24 AM
YYR123's Avatar
YYR123 YYR123 is offline
Originally Posted by Cartoonguy View Post
but I am still amazed that Avid releases an updated Pitch Shift plugin which is so noticeably inferior in the output quality that it is useless,
This is the problem with trusting avid for a subscription model for PT
Close to s year and a half and this doesn't work correctly, doesn't inspire confidence
Daniel
Old 12-01-2014, 07:04 PM
steved5514 steved5514 is offline
i just stumbled across the same issue dropping an octave on a clean guitar clip...I really do not want to install PT10 are there any other options? or do i need to try to buy a new plug in?
Old 01-20-2015, 08:28 PM
drummerandmusician drummerandmusician is offline
Default Re: Pitch II does not work properly!
I have run into the same problem recently after upgrading to PT11. I record a lot of character voices and used the original "Pitch" plugin to do shifting up and down. With "Pitch II" it seems like Avid tried to make their own version of Serato Pitch-N-Time or Waves SoundShifter, but did a poor job of executing. Their use of formant correction is terrible for my purposes… and any purpose.
The work around for me is to use Elastic Audio Properties, which can be a bit more tedious, but it is getting the job done. I would love suggestions on other pitch shift plugins that don't use formant correction.
Old 01-26-2015, 03:13 PM
Timusic8 Timusic8 is offline
Just wanted to weigh in as we are having the same issue here recording dialogue for animation.
I did a full test today pitch shifting spoken word dialogue up 1 semitone in the following configurations, rendering new files using the AudioSuite versions with the exception of the elastic audio version:
Pitch (Pro Tools 10 - all others were done in Pro Tools 11)
Pitch II
Elastic Audio
Time Shift - Polyphonic
Time Shift - Rhythmic
Time Shift - VariSpeed
The original Pitch plugin in Pro Tools 10 produced the best result by far, and is the only version that produced usable results for 100% of the audio file (which is about a minute and a half of different types of dialogue). Time Shift in VariSpeed mode is easily the 2nd place winner with the major caveat that it changes the speed of the resulting file which introduces a whole new set of issues. Time Shift - Rhythmic is probably the next best although Elastic Audio is pretty similar. Unfortunately both of these (and Varispeed for that matter) still occasionally produce unacceptable artifacts for broadcast purposes.
Conclusion - the simplest solution, although inconvenient, is to use the original Pitch plugin with a Pro Tools 10 co-install. Or research other third party plugins and spend some extra cash...
Old 01-26-2015, 04:29 PM
necjamc necjamc is offline
To be honest, this is the only real issue I've had with PT 11 so far. Pitch II does not handle music as well as the original. It's almost unusable compared to the original Pitch.
-Neil
I can't get my Mic to work properly Djgman925 macOS 8 08-22-2013 01:53 PM
does protools ever work properly? pinnacle macOS 9 10-24-2011 04:37 PM
AudioSuite does not work properly. ali3 Pro Tools M-Powered (Mac) 2 04-15-2009 05:13 PM
882 will not work properly with 888 dwall Pro Tools TDM Systems (Win) 0 08-30-2007 12:20 PM
Command 8 not work properly webby ProControl, Control|24, Command|8 3 07-21-2005 09:41 AM
