Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 07-30-2020, 12:57 PM
Kaliber Kaliber is offline
Default Pro tools cant upgrade pcie cards. (aae-1167)
Hello, and thanks for letting me in!
I have a huge problem which needs to be solved ASAP. About a week ago we bought a new machine, iMac 2019 with Catalina on it. Yesterday I connected my Magma Chassi with Pro Tools HDX on it to my Mac, after that I opened Pro Tools and got a message saying that the HDX drivers needs to upgrade. I clicked OK and let Pro Tools upgrade the cards. After 10 minutes, I got a message with a (-1167 failcode). What is the problem? The HDX does work with Logic with no problems and my old MacBook Pro which handles the upgrade fine. I have also run Digitest to ensure that the cards work properly. I have attached some screenshots. Help!
File Type: jpg DE132446-E6A3-40B7-A5BC-27C6F745348B.jpg (25.0 KB, 0 views)
File Type: jpg BAC0FF51-D7DF-4047-9979-499EEB70F76C.jpg (16.2 KB, 0 views)
Old 07-30-2020, 01:12 PM
glogulus2003 glogulus2003 is offline
Default Re: Pro tools cant upgrade pcie cards. (aae-1167)
I had a similar problem with my sonnet chassis and hdx cards on my 2019 iMac. I ended up using an older MacBook Pro that I loaded protools on with the sonnet chassis to do the update on. For some reason the iMac wouldn’t do the update with the sonnet. Worked fine on the iMac after the update though.
Old 07-30-2020, 01:28 PM
Tnx! I used my old MacBook Pro and tried to update the cards that way with PT. Unfortunately the same problem occurred with the MacBook, it freezes and can’t update. I also switched slots for the cards in the chassi, no luck!
Old 07-30-2020, 01:34 PM
JFreak's Avatar
JFreak JFreak is online now
HDX firmware update on chassis has always been problematic, easier to put it inside host computer while updating.
Should work however, if every piece of hardware and software are compatible. So lets start with basic specs...
Janne
Old 07-30-2020, 01:48 PM
Hello. Just did some troubleshooting and came to this conclusion.
I tried to update my PT software to 2020.5 on my other device (MBP which the HDX worked on earlier), and this problem (AAE-1167) started to appear once again. I have used my HDX card with this machine for the latest 6 years w/o any problems at all. So, could it be a bug inside 2020.5?
My basic specs are these.
PT Ultimate 2020.5
Pro Tools HDX with Magma Chassi, connected through thunderbolt
macOS Catalina
iMac 2019 5K
Old 07-30-2020, 01:51 PM
JFreak's Avatar
Which chassis model to be exact? Are you 100% sure it is fully compatible with Catalina?
Janne
Old 07-30-2020, 01:57 PM
Hello again.
I use a Magma EB3T, which for some reason also stopped working on my Mojave machine when I updated to PT 2020.5 (the MBP). It should be compatible with all macOS over Yosemite.
Old 07-30-2020, 02:01 PM
Yes, I’m 100% sure it is compatible since it works on Logic Pro X with zero problems. I think that I have isolated the problems to the PT software since it doesn’t works on any machine with 2020.5 software. I’ve tried with both Mojave and Catalina, but once again since the 2020.5 update, they both fail to upgrade my PCIe cards.
Old 07-30-2020, 02:07 PM
JFreak's Avatar
I think the problem may be with the TB3 ports, which your iMac has.
Cannot find the document right now, but somewhere in the Knowledge Base they say that TB3 chassis are not supported, unless the connection card is replaced with TB2 card which in your case is not feasible as the host computer has TB3.
Janne
Old 07-30-2020, 02:09 PM
Yes, I understand what you mean, but I have a dongle from TB2 to 3 and my MBP which still uses TB 2 doesn’t work either. That can’t be the problem.
Upgrade Options - Mac Pro 1,1 using HD9 , 192io and 3x PCIe HD Cards weezul Pro Tools HDX & HD Native Systems (Mac) 11 06-12-2017 09:13 AM
Wtb pro tools hd2 pcie only the two cards. hart07 Buy & Sell 3 10-26-2012 09:01 AM
Win764 9.03-9.06 upgrade -1167 firmware update errors - need help End Over End Pro Tools 10 0 08-29-2012 01:44 PM
Upgrade quandry - are new PCIe cards faster/better than old PCIx? ajmogis Pro Tools TDM Systems (Mac) 2 04-12-2011 08:33 AM
Magma PE64R Chassis or upgrade PCI cards to PCIe crizdee Pro Tools TDM Systems (Mac) 9 01-27-2008 02:22 AM
