Re: S3L Venue Link trouble
Yes, that is for support in EU, just call them.
According to the manual, Venue Link is now independent from the ECx, I've got the ECx 4.0 installed and still no love.
I'll include a pic, there is a drop-down selection under Advanced Network Settings > Interface: and that is where the IP gets changed on my system time from time. I just need to click on it and when I do, there appears a different IP than it was showing me at first. So I select the new one, and then I'm able to connect the S3L under VENUE Systems. Sorry for the bad quality pic, it's from the manual.
I had the same issue in the very beginning. I created a new network "connection", configured DHCP for it under network settings and called it venue link. so I'm always switching to that one when I'm running venue link. that works great!
Here is the update:
I installed Pro Tools 11.2.2 on another Macbook and it is still the same. Pro Tools can see the console, but after choosing it from the list, the connection remains inactive.
UAD Apollo x16, UAD Apollo Twin Duo, UAD Octo Thunderbolt, Mac Mini i7 2018, Reaper DAW, Presonus Faderport, Arturia Beastep for DAW control, Former Pro Tools HD user (from V7 until V12.6). |
UK Customer Support is helping me out with the issue. I'll post the solution once it gets resolved.
Just maybe it has something to do with 11.2.2? I'm on 11.2.1
This may help if everything else is set up properly and you're still not connecting:
One often overlooked, and not well documented, step in setting up Venue Link is to engage AVB on the computer. Go to the "Audio MIDI Setup" application, drop down the "Window" menu, select "Show Network Device Browser." This will show the devices on AVB that are available. You should be able to engage the separate SL3 components or the 64 i/o stream entirely (that's the way to go.) I believe this all needs to be engaged, or toggled, for Venue Link to engage. Separately, Venue Link works down the same ethernet cable as the record stream, you don't need a separate cable as you've mentioned. Hope that helps! Jacob |
Having trouble getting SC48 to work with Venue link on alternate network interface | blantonlew | VENUE Live Sound Systems | 2 | 07-12-2013 11:36 AM |
Venue link (inactive) | kurt-jen | VENUE Live Sound Systems | 1 | 09-29-2011 08:15 PM |
Venue link issue | digidesigner | VENUE Live Sound Systems | 13 | 07-19-2011 06:44 AM |
Venue Link and VNC | mariojorgeandrade | VENUE Live Sound Systems | 2 | 11-16-2010 08:27 AM |
Cannot link Venue SC48 to laptop with FWx | jmillgrip | VENUE Live Sound Systems | 7 | 03-24-2010 01:05 AM |
