Old 06-11-2022, 03:52 PM
michael c michael c is offline
Default UI Customization
I am messing around with the UI Customization with a Dark theme and for some reason the text is different random colors on the Mix Window. The text is the default setting grey but some text is green on the automation, the delay combination is orange and sometimes green and on other section the text is yellow.
If I change the text color to orange, half the text is orange and all the plug in text is yellow.
Anyone else have this issue?
Thanks.
Mac Pro 3.5GHz 6-core (6.1 2015)
Monterey 12.6.8
64 GB RAM
1 TB PCIe flash storage
Pro Tools Ultimate HD 2023.6
HD Native Thunderbolt
Old 06-12-2022, 01:30 PM
mtmusic mtmusic is offline
Default Re: UI Customization
The delay compensation text changes colors to give you information. That's not a UI customization. The delay comp text is orange for the track that needs the most delay to be compensated (or red if the track is longer than the maximum delay compensation amount) and green for all others. It can also be grey if you want to make it not compensated manually on a track by track basis, or blue for low latency monitoring (so it doesn't delay compensate while recording)
Pro Tools Studio 2022.9
macOS Monterey 12.5.1
Macbook Pro 2021, M1 Max, 64GB RAM
Universal Audio Apollo x16 (x3)
Old 06-12-2022, 01:55 PM
BScout BScout is offline
Blue when auto-low latency is off so it does compensate when in record/input enabled for plugin latency.
(Default behaviour is to turn off compensation when in input enable/record so it has the lowest latency)
Old 06-12-2022, 02:46 PM
Thanks for the info. I don't remember the delay comp text ever being the orange color other than red when it was longer than the max when I used to be in default UI mode. Have you tried making the general text orange? When I do that, it is yellow on the plug ins and even some of the basic track text if the contrast is turned higher than 79.
Monterey 12.6.8
64 GB RAM
S1 / Eucon Customization cunninghamaudio Avid S1, S3, Dock and Control App 1 06-07-2021 10:03 AM
Dock Touch Strips Customization Lynn Gräber Avid S1, S3, Dock and Control App 2 02-26-2020 11:05 PM
iMac Pro Customization Options - Thoughts? DAWgEAR macOS 88 04-06-2018 02:57 PM
Pt9 gui customization Chavdadd macOS 4 07-25-2011 08:29 AM
Plug-in Menu Customization... danander11 General Discussion 5 08-17-2009 05:04 PM
